1292.2
1292.2
    CONTA-CLIP
    THREE-LEVEL INITIATOR TERMINAL
1292.2 数据手册
Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Business data Article number 1292.2 Article name IKD 2,5 NPN/DC/LED(GN)/48V BG GTIN (EAN) 4044211039769 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 15.6 g Weight per piece (including packaging) 17.54 g Unit of weight G Customs number 85369010 Country of origin BG Product description Three-level initiator terminal Colour Beige Creation date 16.12.2023 07:10:34 Subject to technical changes 1 Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Technical data Dimensions Length 84.8 mm Width 5 mm Height TS 35/7.5 58.3 mm Height TS 32 62.8 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.3 W Connection data Connection principle Screw connection Connection position Lateral Connections 6 Number of terminals per level 2 Number of levels 3 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 7 mm Screw head Slotted Screw threading M 2,4 Tightening torque, min. 0.4 Nm Tightening torque, max. 0.8 Nm Creation date 16.12.2023 07:10:34 Subject to technical changes 2 Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 3 End plate required Can be cross-connected Colour of lamp Green LED switching for NPN Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 07:10:34 Subject to technical changes 3 Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup B: rated voltage 300 V CSA Usegroup B: rated current 20 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 14 CSA stripping length 7 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup B: rated voltage 300 V CSAus Usegroup B: rated current 20 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 14 CSAus stripping length 7 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 5.3 Nm cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 07:10:34 Subject to technical changes 4 Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 250 V KEMA rated current 24 A KEMA rated impulse voltage 4 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² KEMA torque, min. 0.4 Nm KEMA torque, max. 0.8 Nm UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 5.3 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 07:10:34 Subject to technical changes 5 Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Media Creation date 16.12.2023 07:10:34 Subject to technical changes 6 Data sheet 1292.2 IKD 2,5 NPN/DC/LED(GN)/48V BG Accessories End plate End plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2699.2 AP 2,5/ID BG 4044211054397 20 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Creation date 16.12.2023 07:10:34 Subject to technical changes 7
1292.2 价格&库存
很抱歉,暂时无法提供与“1292.2”相匹配的价格&库存,您可以联系我们找货
