12930.1
12930.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 3x8P 5.08mm 直插 排数:三排 每排Pin数:8
12930.1 数据手册
Data sheet 12930.1 PKDZ 770/8/5,08-V GN Three-level PCB terminal, Screw connection, No. of poles: 8, Width: 43.18 mm, Colour: Green Business data Article number 12930.1 Article name PKDZ 770/8/5,08-V GN GTIN (EAN) 4044211039851 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 64 g Weight per piece (including packaging) 65.6 g Unit of weight G Customs number 85369010 Country of origin QU Colour Green Creation date 16.12.2023 07:17:39 Subject to technical changes 1 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Technical data Dimensions Length 33.3 mm Length of the pin 5 mm Width 43.18 mm Width left 5.08 mm Width right 2.54 mm Height 44.8 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 22 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 07:17:39 Subject to technical changes 2 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) Number of electrical connections 24 No. of poles 8 Number of levels 3 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 16.12.2023 07:17:39 Subject to technical changes 3 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 07:17:39 Subject to technical changes 4 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 20 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 30 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 30 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 20 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 30 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 30 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 07:17:39 Subject to technical changes 5 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 22 A VDE rated current wire cross-section rigid, max. 22 A VDE rated current wire cross-section stranded, max. 22 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 07:17:39 Subject to technical changes 6 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Media Creation date 16.12.2023 07:17:39 Subject to technical changes 7 Data sheet 12930.1 PKDZ 770/8/5,08-V GN Accessories Creation date 16.12.2023 07:17:39 Subject to technical changes 8
12930.1
物料型号:12930.1 PKDZ 770/8/5,08-V GN
器件简介:三极PCB端子,螺丝连接,8个极,宽度43.18毫米,颜色绿色。
引脚分配:共有24个电气连接,8个极,3个层级。
参数特性: - 额定电压:250V - 额定电流:22A - 额定截面积:2.5 mm² - 额定脉冲电压:2kV - 污染等级:3
功能详解: - 连接原理:螺丝连接 - PCB连接类型:焊接 - 连接角度:0/180°(水平) - 导线截面积范围:单芯(刚性)/绞合,最小0.2 mm²,最大4 mm²
应用信息:适用于需要三极连接的PCB端子应用。
封装信息: - 绝缘体材料:聚酰胺6.6 - 工作温度范围:-30°C至105°C - 存储温度范围:-40°C至105°C
认证信息: - cUL认可:CSA 22.2 No.158 - UL认可:UL1059 - VDE批准:DIN EN60998
12930.1 价格&库存
很抱歉,暂时无法提供与“12930.1”相匹配的价格&库存,您可以联系我们找货
