13045.1
13045.1
    CONTA-CLIP
    P=3.81mm
    接线端子 1x8P 间距:3.81mm 排数:1 每排Pin数:8
13045.1 数据手册
Data sheet 13045.1 PKBZ 1551/8/3,81 GN Female socket block, Screw connection, No. of poles: 8, Width: 30.48 mm, Colour: Green Business data Article number 13045.1 Article name PKBZ 1551/8/3,81 GN GTIN (EAN) 4044211041144 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 6.1 g Weight per piece (including packaging) 6.79 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 16.12.2023 07:24:17 Subject to technical changes 1 Data sheet 13045.1 PKBZ 1551/8/3,81 GN Technical data Dimensions Length 10.4 mm Width 30.48 mm Width left 1.905 mm Width right 1.905 mm Height 19.1 mm Pitch 3.81 mm Ratings Rated voltage 160 V Rated current 8A Rated cross-section 1.5 mm² Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Angle of wire connection/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 8 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.25 mm² Wire cross-section stranded with wire-end ferrules, max. 1 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 16 Stripping length 7 mm Screw threading M2 Torque 0.25 Nm Creation date 16.12.2023 07:24:17 Subject to technical changes 2 Data sheet 13045.1 PKBZ 1551/8/3,81 GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Contact spring Bronze Screws Bronze Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 07:24:17 Subject to technical changes 3 Data sheet 13045.1 PKBZ 1551/8/3,81 GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 8A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 8A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 16 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 16 cUL torque 0.25 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 8A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 8A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 16 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 16 UL torque 2.21 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 07:24:17 Subject to technical changes 4 Data sheet 13045.1 PKBZ 1551/8/3,81 GN Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 160 V VDE rated current 8A VDE rated current wire cross-section rigid, min. 6A VDE rated current wire cross-section rigid, max. 8A VDE rated current wire cross-section stranded, min. 6A VDE rated current wire cross-section stranded, max. 8A VDE rated impulse voltage 2.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M2 VDE torque 0.25 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 07:24:17 Subject to technical changes 5 Data sheet 13045.1 PKBZ 1551/8/3,81 GN Media Creation date 16.12.2023 07:24:17 Subject to technical changes 6 Data sheet 13045.1 PKBZ 1551/8/3,81 GN Accessories Creation date 16.12.2023 07:24:17 Subject to technical changes 7
13045.1 价格&库存
很抱歉,暂时无法提供与“13045.1”相匹配的价格&库存,您可以联系我们找货
