13055.1
13055.1
    CONTA-CLIP
    P=3.81mm
    接线端子 间距:3.81mm 1x18P 自由悬挂
13055.1 数据手册
Data sheet 13055.1 PKBZ 1551/18/3,81 GN Female socket block, Screw connection, No. of poles: 18, Width: 68.58 mm, Colour: Green Business data Article number 13055.1 Article name PKBZ 1551/18/3,81 GN GTIN (EAN) 4044211041243 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 14 g Weight per piece (including packaging) 15.23 g Unit of weight G Customs number 85366930 Country of origin TN Colour Green Creation date 16.12.2023 07:06:58 Subject to technical changes 1 Data sheet 13055.1 PKBZ 1551/18/3,81 GN Technical data Dimensions Length 10.4 mm Width 68.58 mm Width left 1.905 mm Width right 1.905 mm Height 19.1 mm Pitch 3.81 mm Ratings Rated voltage 160 V Rated current 8A Rated cross-section 1.5 mm² Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Angle of wire connection/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 18 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.25 mm² Wire cross-section stranded with wire-end ferrules, max. 1 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 16 Stripping length 7 mm Screw threading M2 Torque 0.25 Nm Creation date 16.12.2023 07:06:58 Subject to technical changes 2 Data sheet 13055.1 PKBZ 1551/18/3,81 GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Contact spring Bronze Screws Bronze Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 07:06:58 Subject to technical changes 3 Data sheet 13055.1 PKBZ 1551/18/3,81 GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 8A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 8A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 16 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 16 cUL torque 0.25 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 8A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 8A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 16 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 16 UL torque 2.21 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 07:06:58 Subject to technical changes 4 Data sheet 13055.1 PKBZ 1551/18/3,81 GN Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 160 V VDE rated current 8A VDE rated current wire cross-section rigid, min. 6A VDE rated current wire cross-section rigid, max. 8A VDE rated current wire cross-section stranded, min. 6A VDE rated current wire cross-section stranded, max. 8A VDE rated impulse voltage 2.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M2 VDE torque 0.25 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 07:06:58 Subject to technical changes 5 Data sheet 13055.1 PKBZ 1551/18/3,81 GN Media Creation date 16.12.2023 07:06:58 Subject to technical changes 6 Data sheet 13055.1 PKBZ 1551/18/3,81 GN Accessories Creation date 16.12.2023 07:06:58 Subject to technical changes 7
13055.1
物料型号为13055.1 PKBZ 1551/18/3,81 GN,提供以下信息:
1. 器件简介:该产品为女性插座块,采用螺钉连接方式,具有18个极位,宽度为68.58毫米,颜色为绿色。
2. 引脚分配:共有18个极位,每个极位的间距为3.81毫米。
3. 参数特性: - 长度:10.4毫米 - 宽度:68.58毫米 - 高度:19.1毫米 - 额定电压:160V - 额定电流:8A - 额定截面积:1.5mm² - 额定脉冲电压:2.5kV - 污染等级:3 - 连接方式:螺钉连接 - 导线截面积:单芯(刚性)/绞合,最小0.14mm²,最大1.5mm²
4. 功能详解: - 绝缘材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C 至 105°C - 固定元件材料:黄铜 - 接触弹簧材料:青铜 - 螺钉材料:青铜 - 绝缘电阻:1x10^13欧姆×厘米 - 爬电电流电阻:CTI600 - 灼热丝可燃性指数:GWFI 850
5. 应用信息:适用于需要18个极位连接的应用场景,如电子设备内部连接。
6. 封装信息: - 包装单位:50个/箱 - 包装类型:纸箱 - 重量(不含包装):14克/个 - 重量(含包装):15.23克/个
该产品还需注意技术变化的可能性。
13055.1 价格&库存
很抱歉,暂时无法提供与“13055.1”相匹配的价格&库存,您可以联系我们找货
