13126.0
13126.0
    CONTA-CLIP
    插件,P=5mm
    接线端子 间距:5.00mm 每排针脚数:20 排数:单排
13126.0 数据手册
Data sheet 13126.0 PBK 4101/20/5,00-KD LG Female socket block, Push-in connection, No. of poles: 20, Width: 101.6 mm, Colour: Pebble grey Business data Article number 13126.0 Article name PBK 4101/20/5,00-KD LG GTIN (EAN) 4044211042011 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 13.3 g Weight per piece (including packaging) 14.95 g Unit of weight G Customs number 85366930 Country of origin QU Colour Pebble grey Creation date 16.12.2023 07:18:06 Subject to technical changes 1 Data sheet 13126.0 PBK 4101/20/5,00-KD LG Technical data Dimensions Length 12.5 mm Length of the pin 3.6 mm Width 101.6 mm Width left 3.5 mm Width right 3.1 mm Height 9.2 mm Drill hole diameter 1 mm Diameter of connecting pin 0.4 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Push-in connection Connection type of PCB Connecting contact Type of attachment to circuit board Solder connection Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 20 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.5 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 14 Stripping length 9 mm Creation date 16.12.2023 07:18:06 Subject to technical changes 2 Data sheet 13126.0 PBK 4101/20/5,00-KD LG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Terminal spring Stainless steel Soldering lug Copper alloy Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 07:18:06 Subject to technical changes 3 Data sheet 13126.0 PBK 4101/20/5,00-KD LG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 20 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 20 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 07:18:06 Subject to technical changes 4 Data sheet 13126.0 PBK 4101/20/5,00-KD LG Media Creation date 16.12.2023 07:18:06 Subject to technical changes 5 Data sheet 13126.0 PBK 4101/20/5,00-KD LG Accessories Creation date 16.12.2023 07:18:06 Subject to technical changes 6
13126.0 价格&库存
很抱歉,暂时无法提供与“13126.0”相匹配的价格&库存,您可以联系我们找货
