13158.1
13158.1
    CONTA-CLIP
    插件,P=5.08mm
    HEADER
13158.1 数据手册
Data sheet 13158.1 STL 950/6/5,08-G-L Business data Article number 13158.1 Article name STL 950/6/5,08-G-L GTIN (EAN) 4044211042363 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Unit of weight G Customs number 85366930 Country of origin EU Creation date 11.11.2023 21:27:21 Subject to technical changes 1 Data sheet 13158.1 STL 950/6/5,08-G-L Technical data Dimensions Height 12 mm Diameter of connecting pin 1 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Number of plug-in rows 1 No. of poles 6 Further technical data Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Materials Contact pin Creation date 11.11.2023 21:27:21 Copper alloy Subject to technical changes 2 Data sheet 13158.1 STL 950/6/5,08-G-L Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 11.11.2023 21:27:21 Subject to technical changes 3 Data sheet 13158.1 STL 950/6/5,08-G-L Media Creation date 11.11.2023 21:27:21 Subject to technical changes 4 Data sheet 13158.1 STL 950/6/5,08-G-L Accessories Creation date 11.11.2023 21:27:21 Subject to technical changes 5
13158.1 价格&库存
很抱歉,暂时无法提供与“13158.1”相匹配的价格&库存,您可以联系我们找货
