13243.1
13243.1
    CONTA-CLIP
    插件,P=5mm
    接线端子 间距:5.00mm 1x14P 直插
13243.1 数据手册
Data sheet 13243.1 STL 950/14/5,00-V-F GN Male pin block, No. of poles: 14, Width: 80 mm, Colour: Green Business data Article number 13243.1 Article name STL 950/14/5,00-V-F GN GTIN (EAN) 4044211043384 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 5.2 g Weight per piece (including packaging) 5.7 g Unit of weight G Customs number 85366930 Country of origin QU Colour Green Creation date 16.12.2023 08:09:53 Subject to technical changes 1 Data sheet 13243.1 STL 950/14/5,00-V-F GN Technical data Dimensions Length 8.4 mm Length of the pin 3.9 mm Width 80 mm Width left 7.5 mm Width right 7.5 mm Height 12 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 14 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Flange, threaded insert Brass Creation date 16.12.2023 08:09:53 Subject to technical changes 2 Data sheet 13243.1 STL 950/14/5,00-V-F GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 08:09:53 Subject to technical changes 3 Data sheet 13243.1 STL 950/14/5,00-V-F GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 08:09:53 Subject to technical changes 4 Data sheet 13243.1 STL 950/14/5,00-V-F GN Media Creation date 16.12.2023 08:09:53 Subject to technical changes 5 Data sheet 13243.1 STL 950/14/5,00-V-F GN Accessories Creation date 16.12.2023 08:09:53 Subject to technical changes 6
13243.1
物料型号:13243.1 STL 950/14/5,00-V-F GN
器件简介:这是一个公头端子排,具有14个极位,宽度为80毫米,颜色为绿色。
引脚分配:共有14个极位,每个极位的引脚直径为1毫米,间距为5毫米。
参数特性: - 额定电压:250V - 额定电流:12A - 额定脉冲电压:4kV - 污染等级:3 - 工作温度:-30°C 至 105°C - 存储温度:-40°C 至 105°C - 绝缘电阻:110^13欧姆x厘米 - 爬电距离电流电阻:CTI600 - 灼热丝可燃性指数GWFI:850°C - 灼热丝点燃温度GWIT:775°C
功能详解:端子排设计用于垂直向上连接,并具有一个插入式连接器版本,包装单位为50个/箱。
应用信息:适用于需要电气连接的应用,具体应用场景未在文档中详述。
封装信息:绝缘材料为聚酰胺6.6,阻燃等级为UL94 V-0。
13243.1 价格&库存
很抱歉,暂时无法提供与“13243.1”相匹配的价格&库存,您可以联系我们找货
