12644.4
12644.4
    CONTA-CLIP
    插件,P=5mm
    PCB TERMINAL
12644.4 数据手册
Data sheet 12644.4 PK 700/24/5,00-H DG PCB terminal, Screw connection, No. of poles: 24, Width: 120.6 mm, Colour: Dark grey Business data Article number 12644.4 Article name PK 700/24/5,00-H DG GTIN (EAN) 4044211036133 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 35.7 g Weight per piece (including packaging) 37.7 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 12644.1 Creation date 14.12.2023 21:23:17 Subject to technical changes 1 Data sheet 12644.4 PK 700/24/5,00-H DG Technical data Dimensions Length 10.5 mm Length of the pin 4 mm Width 120.6 mm Width left 3.1 mm Width right 2.5 mm Height 19 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.9 mm Pitch 5 mm Ratings Rated voltage 250 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Creation date 14.12.2023 21:23:17 Subject to technical changes 2 Data sheet 12644.4 PK 700/24/5,00-H DG Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 24 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 2.5 mm² Wire cross-section AWG, min. 30 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Copper alloy Creation date 14.12.2023 21:23:17 Subject to technical changes 3 Data sheet 12644.4 PK 700/24/5,00-H DG Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 14.12.2023 21:23:17 Subject to technical changes 4 Data sheet 12644.4 PK 700/24/5,00-H DG Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 15 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.4499999881 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 15 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 4 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 21:23:17 Subject to technical changes 5 Data sheet 12644.4 PK 700/24/5,00-H DG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 24 A VDE rated current wire cross-section rigid, max. 24 A VDE rated current wire cross-section stranded, max. 24 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 4 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 21:23:17 Subject to technical changes 6 Data sheet 12644.4 PK 700/24/5,00-H DG Media Creation date 14.12.2023 21:23:17 Subject to technical changes 7 Data sheet 12644.4 PK 700/24/5,00-H DG Accessories Creation date 14.12.2023 21:23:17 Subject to technical changes 8
12644.4
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出信号。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-55至125度,隔离电压为2500Vrms。
5. 功能详解:EL817通过光电效应实现信号隔离,提高系统稳定性和安全性。
6. 应用信息:EL817适用于工业控制系统、医疗设备等需要信号隔离的场合。
7. 封装信息:EL817采用DIP-6封装。
12644.4 价格&库存
很抱歉,暂时无法提供与“12644.4”相匹配的价格&库存,您可以联系我们找货
