Data sheet
13409.1 PZK 3750/5/5,08-VP GN
Double-level PCB terminal, Tension-spring connection, No. of poles: 5, Width: 27.1 mm, Colour: Green
Business data
Article number
13409.1
Article name
GTIN (EAN)
4044211082659
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
12.5 g
Weight per piece (including packaging)
13.8 g
Unit of weight
G
Customs number
85369010
Country of origin
QU
Colour
Green
Creation date 15.12.2023 17:07:21
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
21 mm
Length of the pin
4 mm
Width
27.1 mm
Width left
2.5 mm
Width right
4.28 mm
Height
25.7 mm
Drill hole diameter
1.3 mm
Diameter of connecting pin
0.7 mm
Pitch
5.08 mm
Ratings
Rated voltage
250 V
Rated current
12 A
Rated cross-section
2.5 mm²
Rated impulse voltage
2 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Connection type of PCB
Solder connection
Type of attachment to circuit board
Connecting contact
Angle of PCB/wire connection
45°/135° (slanted upwards)
No. of poles
5
Number of levels
2
Wire cross-section single-core (rigid) / stranded, min.
0.08 mm²
Wire cross-section single core (rigid)/stranded, max.
2.5 mm²
Wire cross-section stranded, min.
0.14 mm²
Wire cross-section stranded, max.
2.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.14 mm²
max.
1.5 mm²
Wire cross-section AWG, min.
28
Wire cross-section AWG, max.
14
Stripping length
6 mm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Tension spring
Stainless steel
Soldering lug
Copper alloy
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
10
Recommended wave soldering temperature
265 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
16 A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
10 A
cUL wire cross-section single-core (rigid) AWG, min.
28
cUL wire cross-section single-core (rigid) AWG, max. 14
cUL wire cross-section stranded AWG, min.
28
cUL wire cross-section stranded AWG, max.
14
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
16 A
300 V
10 A
28
14
28
14
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
4
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 60998
VDE approval granted
yes
VDE rated voltage
250 V
VDE rated current
12 A
VDE rated current wire cross-section rigid, max.
12 A
VDE rated current wire cross-section stranded, max.
12 A
VDE rated impulse voltage
2 kV
VDE wire cross-section rigid, min.
0.5 mm²
VDE wire cross-section rigid, max.
2.5 mm²
VDE wire cross-section stranded, min.
0.5 mm²
VDE wire cross-section stranded, max.
2.5 mm²
VDE overvoltage category
III
VDE contamination degree
3
5
Data sheet
Media
6
Data sheet
Accessories
7
很抱歉,暂时无法提供与“13409.1”相匹配的价格&库存,您可以联系我们找货
