13426.1
13426.1
    CONTA-CLIP
    插件
    接线端子
13426.1 数据手册
Data sheet 13426.1 PZK 3750/22/5,08-VP GN Double-level PCB terminal, Tension-spring connection, No. of poles: 22, Width: 113.46 mm, Colour: Green Business data Article number 13426.1 Article name PZK 3750/22/5,08-VP GN GTIN (EAN) 4044211082826 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 55 g Weight per piece (including packaging) 56.6 g Unit of weight G Customs number 85369010 Country of origin QU Colour Green Creation date 16.12.2023 08:02:26 Subject to technical changes 1 Data sheet 13426.1 PZK 3750/22/5,08-VP GN Technical data Dimensions Length 21 mm Length of the pin 4 mm Width 113.46 mm Width left 2.5 mm Width right 4.28 mm Height 25.7 mm Drill hole diameter 1.3 mm Diameter of connecting pin 0.7 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 12 A Rated cross-section 2.5 mm² Rated impulse voltage 2 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Tension-spring connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 45°/135° (slanted upwards) No. of poles 22 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 14 Stripping length 6 mm Creation date 16.12.2023 08:02:26 Subject to technical changes 2 Data sheet 13426.1 PZK 3750/22/5,08-VP GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Tension spring Stainless steel Soldering lug Copper alloy Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 10 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 08:02:26 Subject to technical changes 3 Data sheet 13426.1 PZK 3750/22/5,08-VP GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 16 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 14 cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 16 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 14 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 08:02:26 Subject to technical changes 4 Data sheet 13426.1 PZK 3750/22/5,08-VP GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated current wire cross-section rigid, max. 12 A VDE rated current wire cross-section stranded, max. 12 A VDE rated impulse voltage 2 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 08:02:26 Subject to technical changes 5 Data sheet 13426.1 PZK 3750/22/5,08-VP GN Media Creation date 16.12.2023 08:02:26 Subject to technical changes 6 Data sheet 13426.1 PZK 3750/22/5,08-VP GN Accessories Creation date 16.12.2023 08:02:26 Subject to technical changes 7
13426.1 价格&库存
很抱歉,暂时无法提供与“13426.1”相匹配的价格&库存,您可以联系我们找货
