13438.1
13438.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 间距:5.08mm 2x11P 直插
13438.1 数据手册
Data sheet 13438.1 STL 970/11/5,08-V-G GN Male pin block, No. of poles: 11, Width: 63.5 mm, Colour: Green Business data Article number 13438.1 Article name STL 970/11/5,08-V-G GN GTIN (EAN) 4044211082949 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 14.3 g Weight per piece (including packaging) 15.9 g Unit of weight G Customs number 85366930 Country of origin QU Colour Green Creation date 16.12.2023 08:12:16 Subject to technical changes 1 Data sheet 13438.1 STL 970/11/5,08-V-G GN Technical data Dimensions Length 23.5 mm Length of the pin 3.9 mm Width 63.5 mm Width left 5.08 mm Width right 7.62 mm Height 22 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 90° (vertically upwards) Number of plug-in rows 2 No. of poles 11 Materials Insulation housing Polybutylene terephthalate Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Copper alloy Creation date 16.12.2023 08:12:16 Subject to technical changes 2 Data sheet 13438.1 STL 970/11/5,08-V-G GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 175 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 08:12:16 Subject to technical changes 3 Data sheet 13438.1 STL 970/11/5,08-V-G GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 08:12:16 Subject to technical changes 4 Data sheet 13438.1 STL 970/11/5,08-V-G GN Media Creation date 16.12.2023 08:12:16 Subject to technical changes 5 Data sheet 13438.1 STL 970/11/5,08-V-G GN Accessories Creation date 16.12.2023 08:12:16 Subject to technical changes 6
13438.1
- 物料型号: 13438.1 STL 970/11/5,08-V-G GN - 器件简介: 这是一个带有11个插针的男性端子块,宽度为63.5毫米,颜色为绿色。 - 引脚分配: 共有11个插针,间距为5.08毫米。 - 参数特性: - 额定电压: 250V - 额定电流: 12A - 额定脉冲电压: 4kV - 污染等级: 3 - 工作温度范围: -30°C 至 105°C - 存储温度范围: -40°C 至 105°C - 功能详解: - 绝缘材料: Polybutylene terephthalate - 阻燃等级: UL 94 V-0 - 绝缘电阻: 110^13 Ohm x cm - 爬电电流电阻: CTI 175 - 灼热丝可燃性指数: GWFI 850 - 灼热丝点火温度: GWIT 775°C - 插拔寿命: 100次 - 应用信息: 适用于多种电子设备连接。 - 封装信息: 包装单位为50个/箱,包装类型为纸盒。
13438.1 价格&库存
很抱歉,暂时无法提供与“13438.1”相匹配的价格&库存,您可以联系我们找货
    • 1+62.05680
    • 200+24.01920
    • 500+23.17680
    • 1000+22.75560
