Data sheet
13445.1 STL 970/7/5,08-H-G GN
Male pin block, No. of poles: 7, Width: 43.18 mm, Colour: Green
Business data
Article number
13445.1
Article name
GTIN (EAN)
4044211083014
Connector version
Attached plug-in connector
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
9.1 g
Weight per piece (including packaging)
10.2 g
Unit of weight
G
Customs number
85366930
Country of origin
TN
Colour
Green
Creation date 16.12.2023 07:52:33
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
22 mm
Length of the pin
3.5 mm
Width
43.18 mm
Width left
5.08 mm
Width right
7.62 mm
Height
23.5 mm
Drill hole diameter
1.4 mm
Diameter of connecting pin
1 mm
Pitch
5.08 mm
Ratings
Rated voltage
250 V
Rated current
12 A
Rated impulse voltage
4 kV
Overvoltage category
III
Contamination degree
3
Connection data
Angle of PCB/contact
0°/180° (horizontal)
Number of plug-in rows
2
No. of poles
7
Materials
Insulation housing
Polybutylene terephthalate
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Contact pin
Copper alloy
2
Data sheet
Technical data
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 175
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Plug-in cycles acc. to standard
100
Recommended wave soldering temperature
265 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
15 A
cUL Usegroup C: rated voltage
150 V
cUL Usegroup C: rated current
15 A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
10 A
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
15 A
150 V
15 A
300 V
10 A
UL wire material
Cu
UL factory wiring
1
UL Recognized
1
VDE approval
VDE approval
DIN EN 61984
VDE approval granted
yes
VDE rated voltage
250 V
VDE rated current
12 A
VDE rated impulse voltage
4 kV
VDE overvoltage category
III
VDE contamination degree
3
4
Data sheet
Media
5
Data sheet
Accessories
6
很抱歉,暂时无法提供与“13445.1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+44.23680
- 200+17.11800
- 500+16.52400
- 1000+16.22160
