13476.1
13476.1
    CONTA-CLIP
    插件,P=10mm
    接线端子 1x16P 10mm 直插 排数:单排 每排Pin数:16
13476.1 数据手册
Data sheet 13476.1 PK 500/16/10,00-V GN PCB terminal, Wire protection, No. of poles: 16, Width: 155.6 mm, Colour: Green Business data Article number 13476.1 Article name PK 500/16/10,00-V GN GTIN (EAN) 4044211083335 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 17.6 g Weight per piece (including packaging) 18.5 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 13476.1 Creation date 16.12.2023 07:58:40 Subject to technical changes 1 Data sheet 13476.1 PK 500/16/10,00-V GN Technical data Dimensions Length 7.5 mm Length of the pin 4.5 mm Width 155.6 mm Width left 3.1 mm Width right 2.5 mm Height 10 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 10 mm Ratings Rated voltage 750 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 3.5 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 07:58:40 Subject to technical changes 2 Data sheet 13476.1 PK 500/16/10,00-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 16 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 5 mm Screw threading M 2,6 Torque 0.4 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 07:58:40 Subject to technical changes 3 Data sheet 13476.1 PK 500/16/10,00-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 07:58:40 Subject to technical changes 4 Data sheet 13476.1 PK 500/16/10,00-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 14 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.400000006 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 22 UL torque 3.54 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 07:58:40 Subject to technical changes 5 Data sheet 13476.1 PK 500/16/10,00-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 3.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M 2,6 VDE torque 0.4 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 07:58:40 Subject to technical changes 6 Data sheet 13476.1 PK 500/16/10,00-V GN Media Creation date 16.12.2023 07:58:40 Subject to technical changes 7 Data sheet 13476.1 PK 500/16/10,00-V GN Accessories Creation date 16.12.2023 07:58:40 Subject to technical changes 8
13476.1
1. 物料型号:13476.1 PK 500/16/10,00-V GN,一种PCB端子,用于线缆保护,有16个插脚,宽度为155.6毫米,颜色为绿色。
2. 器件简介:该端子主要用于PCB端的线缆保护,具有16个插脚,额定电压750V,额定电流17.5A,连接线径范围从0.2mm²至1.5mm²。
3. 引脚分配:端子宽度为155.6mm,左侧宽度为3.1mm,右侧宽度为2.5mm,高度为10mm,连接销直径为1mm,间距为10mm。
4. 参数特性:包括额定电压750V,额定电流17.5A,额定截面积1.5mm²,额定脉冲电压3.5kV,爬电距离CTI 600,绝缘电阻110^13欧姆x厘米等。
5. 功能详解:端子采用连接接触方式连接到PCB,连接原理为线缆保护,适用于0°/180°水平连接,具有16个插脚,1层,适用于不同线径的线缆。
6. 应用信息:端子的工作环境温度范围为-30°C至105°C,存储温度范围为-40°C至105°C,符合VDE和UL认证标准,适用于多种线缆连接。
7. 封装信息:绝缘体材料为聚酰胺6.6,阻燃等级为V-0,连接元件材料为黄铜,螺钉材料为钢,线缆保护材料为不锈钢。
13476.1 价格&库存
很抱歉,暂时无法提供与“13476.1”相匹配的价格&库存,您可以联系我们找货
