13481.1
13481.1
    CONTA-CLIP
    插件,P=10mm
    接线端子 1x21P 10mm 直插 排数:单排 每排Pin数:21
13481.1 数据手册
Data sheet 13481.1 PK 500/21/10,00-V GN PCB terminal, Wire protection, No. of poles: 21, Width: 205.6 mm, Colour: Green Business data Article number 13481.1 Article name PK 500/21/10,00-V GN GTIN (EAN) 4044211083380 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 23.1 g Weight per piece (including packaging) 24.1 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 13481.1 Creation date 16.12.2023 08:09:53 Subject to technical changes 1 Data sheet 13481.1 PK 500/21/10,00-V GN Technical data Dimensions Length 7.5 mm Length of the pin 4.5 mm Width 205.6 mm Width left 3.1 mm Width right 2.5 mm Height 10 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 10 mm Ratings Rated voltage 750 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 3.5 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 08:09:53 Subject to technical changes 2 Data sheet 13481.1 PK 500/21/10,00-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 21 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 5 mm Screw threading M 2,6 Torque 0.4 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 08:09:53 Subject to technical changes 3 Data sheet 13481.1 PK 500/21/10,00-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 08:09:53 Subject to technical changes 4 Data sheet 13481.1 PK 500/21/10,00-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 14 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.400000006 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 22 UL torque 3.54 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 08:09:53 Subject to technical changes 5 Data sheet 13481.1 PK 500/21/10,00-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 3.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M 2,6 VDE torque 0.4 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 08:09:53 Subject to technical changes 6 Data sheet 13481.1 PK 500/21/10,00-V GN Media Creation date 16.12.2023 08:09:53 Subject to technical changes 7 Data sheet 13481.1 PK 500/21/10,00-V GN Accessories Creation date 16.12.2023 08:09:53 Subject to technical changes 8
13481.1
物料型号:13481.1 PK 500/21/10,00-V GN
器件简介:这是一种PCB端子,具有21个极位,宽度为205.6毫米,颜色为绿色,用于导线保护。
引脚分配:该器件具有21个极位,每个极位的间距为10毫米。
参数特性: - 额定电压:750V - 额定电流:17.5A - 额定截面积:1.5mm² - 额定脉冲电压:3.5kV - 污染等级:3
功能详解: - 连接原理:导线保护 - 连接类型:焊接 - 连接角度:0°/180°(水平) - 导线截面积范围:0.2mm²至1.5mm² - 剥离长度:5mm - 螺丝规格:M2.6 - 扭矩:0.4Nm
应用信息:适用于连接PCB并提供导线保护。
封装信息: - 绝缘材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C至105°C - 压接元件:黄铜 - 螺丝:钢 - 导线保护:不锈钢
13481.1 价格&库存
很抱歉,暂时无法提供与“13481.1”相匹配的价格&库存,您可以联系我们找货
    • 1+38.28600
    • 200+14.81760
    • 500+14.29920
    • 1000+14.04000
