13528.1
13528.1
    CONTA-CLIP
    插件,P=10.16mm
    PCB TERMINAL
13528.1 数据手册
Data sheet 13528.1 PK 500/20/10,16-V GN PCB terminal, Wire protection, No. of poles: 20, Width: 198.72 mm, Colour: Green Business data Article number 13528.1 Article name PK 500/20/10,16-V GN GTIN (EAN) 4044211084318 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 22 g Weight per piece (including packaging) 22.9 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 13528.1 Creation date 16.12.2023 20:02:24 Subject to technical changes 1 Data sheet 13528.1 PK 500/20/10,16-V GN Technical data Dimensions Length 7.5 mm Length of the pin 4.5 mm Width 198.72 mm Width left 3.14 mm Width right 2.54 mm Height 10 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 10.16 mm Ratings Rated voltage 750 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 3.5 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 20:02:24 Subject to technical changes 2 Data sheet 13528.1 PK 500/20/10,16-V GN Technical data Connection data Connection principle Wire protection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 0°/180° (horizontal) No. of poles 20 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.2 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 5 mm Screw threading M 2,6 Torque 0.4 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Wire protection Stainless steel Creation date 16.12.2023 20:02:24 Subject to technical changes 3 Data sheet 13528.1 PK 500/20/10,16-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 260 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 20:02:24 Subject to technical changes 4 Data sheet 13528.1 PK 500/20/10,16-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 15 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 14 cUL wire cross-section stranded AWG, min. 14 cUL wire cross-section stranded AWG, max. 22 cUL torque 0.400000006 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 15 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 14 UL wire cross-section stranded AWG, min. 14 UL wire cross-section stranded AWG, max. 22 UL torque 3.54 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:02:24 Subject to technical changes 5 Data sheet 13528.1 PK 500/20/10,16-V GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 3.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M 2,6 VDE torque 0.4 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 20:02:24 Subject to technical changes 6 Data sheet 13528.1 PK 500/20/10,16-V GN Media Creation date 16.12.2023 20:02:24 Subject to technical changes 7 Data sheet 13528.1 PK 500/20/10,16-V GN Accessories Creation date 16.12.2023 20:02:24 Subject to technical changes 8
13528.1
物料型号:13528.1 PK 500/20/10,16-V GN
器件简介:这是一个20极的PCB端子,用于电线保护,宽度为198.72毫米,颜色为绿色。
引脚分配:共有20个引脚,引脚间距为10.16毫米。
参数特性: - 额定电压:750V - 额定电流:17.5A - 额定截面积:1.5mm² - 额定脉冲电压:3.5kV - 污染等级:3
功能详解: - 连接原理:电线保护 - 连接类型:焊接连接 - 连接角度:0°/180°(水平) - 适用电线截面积:单芯(刚性)/绞合,最小0.2mm²,最大1.5mm² - 剥离长度:5mm - 螺丝螺纹:M2.6 - 扭矩:0.4Nm
应用信息: - 工作温度范围:-30°C 至 105°C - 存储温度范围:-40°C 至 105°C - 绝缘电阻:110^13 Ohm x cm - 爬电电流电阻:CTI 600
封装信息: - 绝缘体材料:聚酰胺6.6 - 阻燃等级:UL 94 V-0 - 压接元件:黄铜 - 螺丝:钢 - 电线保护:不锈钢
认证信息包括cUL、CSA、UL和VDE等。
13528.1 价格&库存
很抱歉,暂时无法提供与“13528.1”相匹配的价格&库存,您可以联系我们找货
