1356.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL FOR DIRECT
1356.2 数据手册
Data sheet 1356.2 BKA 2,5/8 b.B. BG Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated crosssection: 2.5 mm², Colour: Beige Business data Article number 1356.2 Article name BKA 2,5/8 b.B. BG GTIN (EAN) 4044211044046 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 32 g Weight per piece (including packaging) 35 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1356.2 Product description Feed-through terminal for direct mount Creation date 15.12.2023 02:07:47 Subject to technical changes 1 Data sheet 1356.2 BKA 2,5/8 b.B. BG Technical data Dimensions Length 55.1 mm Height 23 mm Hole spacing (mid-point to mid-point) 48 mm Pitch 5 mm Ratings Rated voltage 400 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.77 W Connection data Connection principle Screw connection Connection position Lateral Connections 16 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 7 mm Screw head Slotted Screw threading M 2,5 Tightening torque, min. 0.4 Nm Tightening torque, max. 0.8 Nm Creation date 15.12.2023 02:07:47 Subject to technical changes 2 Data sheet 1356.2 BKA 2,5/8 b.B. BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A3 End plate required Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 02:07:47 No Subject to technical changes 3 Data sheet 1356.2 BKA 2,5/8 b.B. BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 20 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 20 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 5.3 Nm cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 24 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² KEMA torque, min. 0.4 Nm KEMA torque, max. 0.8 Nm Creation date 15.12.2023 02:07:47 Subject to technical changes 4 Data sheet 1356.2 BKA 2,5/8 b.B. BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 20 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 5.3 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 02:07:47 Subject to technical changes 5 Data sheet 1356.2 BKA 2,5/8 b.B. BG Media Creation date 15.12.2023 02:07:47 Subject to technical changes 6 Data sheet 1356.2 BKA 2,5/8 b.B. BG Accessories Insulated external cross-connector External insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.1 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2045.0 AQI 10/5/11 YE 4044211048501 10 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.36 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2033.0 AQI 3/5/11 YE 4044211048358 50 ST External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.26 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2032.0 AQI 2/5/11 YE 4044211048341 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.46 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2044.0 AQI 4/5/11 YE 4044211048495 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Screwdriver Creation date 15.12.2023 02:07:47 Subject to technical changes 7 Data sheet 1356.2 BKA 2,5/8 b.B. BG Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Creation date 15.12.2023 02:07:47 Subject to technical changes 8
1356.2 价格&库存
很抱歉,暂时无法提供与“1356.2”相匹配的价格&库存,您可以联系我们找货
