13608.4
13608.4
    CONTA-CLIP
    插件,P=7.5mm
    接线端子 1x5P 7.5mm 直插 排数:单排 每排Pin数:5
13608.4 数据手册
Data sheet 13608.4 PK 360/5/7,50-H DG PCB terminal, Screw connection, No. of poles: 5, Width: 38.1 mm, Colour: Dark grey Business data Article number 13608.4 Article name PK 360/5/7,50-H DG GTIN (EAN) 4044211086145 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 7g Weight per piece (including packaging) 8g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 13608.1 Creation date 16.12.2023 20:01:02 Subject to technical changes 1 Data sheet 13608.4 PK 360/5/7,50-H DG Technical data Dimensions Length 9 mm Length of the pin 3.5 mm Width 38.1 mm Width left 4.35 mm Width right 3.75 mm Height 13.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 7.5 mm Ratings Rated voltage 750 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Creation date 16.12.2023 20:01:02 Subject to technical changes 2 Data sheet 13608.4 PK 360/5/7,50-H DG Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 5 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 6 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Brass Creation date 16.12.2023 20:01:02 Subject to technical changes 3 Data sheet 13608.4 PK 360/5/7,50-H DG Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 16.12.2023 20:01:02 Subject to technical changes 4 Data sheet 13608.4 PK 360/5/7,50-H DG Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 16 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 16 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 16 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.5 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 16 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 16 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 16 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 4.43 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:01:02 Subject to technical changes 5 Data sheet 13608.4 PK 360/5/7,50-H DG Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 20:01:02 Subject to technical changes 6 Data sheet 13608.4 PK 360/5/7,50-H DG Media Creation date 16.12.2023 20:01:02 Subject to technical changes 7 Data sheet 13608.4 PK 360/5/7,50-H DG Accessories Creation date 16.12.2023 20:01:02 Subject to technical changes 8
13608.4
1. 物料型号:型号为ATMEGA16-16AU,是一种基于AVR增强型8位单片机。
2. 器件简介:ATMEGA16-16AU具有16KB的闪存、1KB的SRAM、512B的EEPROM、8个通用10位ADC通道、可编程看门狗定时器、实时计数器等。
3. 引脚分配:该单片机有40个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8-5.5V,工作频率为16MHz,最大功耗为55mW。
5. 功能详解:详细介绍了ATMEGA16-16AU的各个功能模块,包括CPU、存储器、I/O端口、定时器等。
6. 应用信息:适用于需要高性能、低功耗的嵌入式系统。
7. 封装信息:采用TQFP44封装。
13608.4 价格&库存
很抱歉,暂时无法提供与“13608.4”相匹配的价格&库存,您可以联系我们找货
