13612.1
13612.1
    CONTA-CLIP
    插件,P=7.5mm
    接线端子 1x9P 7.5mm 直插 排数:单排 每排Pin数:9
13612.1 数据手册
Data sheet 13612.1 PK 360/9/7,50-H GN PCB terminal, Screw connection, No. of poles: 9, Width: 68.1 mm, Colour: Green Business data Article number 13612.1 Article name PK 360/9/7,50-H GN GTIN (EAN) 4044211085797 Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 12.6 g Weight per piece (including packaging) 13.6 g Unit of weight G Customs number 85369010 Country of origin QU Prio-Article 13612.1 Creation date 15.12.2023 02:11:11 Subject to technical changes 1 Data sheet 13612.1 PK 360/9/7,50-H GN Technical data Dimensions Length 9 mm Length of the pin 3.5 mm Width 68.1 mm Width left 4.35 mm Width right 3.75 mm Height 13.5 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 7.5 mm Ratings Rated voltage 750 V Rated current 17.5 A Rated cross-section 1.5 mm² Rated impulse voltage 3 kV Overvoltage category III Contamination degree 3 Creation date 15.12.2023 02:11:11 Subject to technical changes 2 Data sheet 13612.1 PK 360/9/7,50-H GN Technical data Connection data Connection principle Screw connection Connection type of PCB Solder connection Type of attachment to circuit board Connecting contact Angle of PCB/wire connection 90° (vertically upwards) No. of poles 9 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.14 mm² Wire cross-section single core (rigid)/stranded, max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules,min. 0.25 mm² Wire cross-section stranded with wire-end ferrules,max. 1.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 6 mm Screw threading M3 Torque 0.5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Screws Steel Soldering lug Brass Creation date 15.12.2023 02:11:11 Subject to technical changes 3 Data sheet 13612.1 PK 360/9/7,50-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 15.12.2023 02:11:11 Subject to technical changes 4 Data sheet 13612.1 PK 360/9/7,50-H GN Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 16 A cUL Usegroup C: rated voltage 300 V cUL Usegroup C: rated current 16 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 16 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.5 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 16 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 16 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 16 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 4.43 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 02:11:11 Subject to technical changes 5 Data sheet 13612.1 PK 360/9/7,50-H GN Approvals VDE approval VDE approval DIN EN 60998 VDE approval granted yes VDE rated voltage 750 V VDE rated current 17.5 A VDE rated current wire cross-section rigid, max. 17.5 A VDE rated current wire cross-section stranded, max. 17.5 A VDE rated impulse voltage 3 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 15.12.2023 02:11:11 Subject to technical changes 6 Data sheet 13612.1 PK 360/9/7,50-H GN Media Creation date 15.12.2023 02:11:11 Subject to technical changes 7 Data sheet 13612.1 PK 360/9/7,50-H GN Accessories Creation date 15.12.2023 02:11:11 Subject to technical changes 8
13612.1
物料型号: - 文章编号:13612.1 - 文章名称:PK360/9/7,50-H GN - GTIN (EAN):4044211085797
器件简介: - 产品类型:PCB端子,螺丝连接 - 极数:9 - 宽度:68.1毫米 - 颜色:绿色
引脚分配: - 长度:9毫米 - 引脚长度:3.5毫米 - 高度:13.5毫米 - 钻孔直径:1.3毫米 - 连接销直径:1毫米 - 间距:7.5毫米
参数特性: - 额定电压:750V - 额定电流:17.5A - 额定截面积:1.5 mm² - 额定脉冲电压:3kV - 污染等级:3
功能详解: - 连接原理:螺丝连接 - 连接类型:PCB焊接 - 连接角度:90°(垂直向上) - 导线截面积范围:0.14mm² 至 2.5mm² - 螺丝规格:M3 - 扭矩:0.5Nm
应用信息: - 材料:聚酰胺6.6(绝缘体),黄铜(夹持元件),钢(螺丝) - 工作温度范围:-30°C 至 105°C - 存储温度范围:-40°C 至 105°C - 绝缘电阻:110^13欧姆x厘米
封装信息: - 认证:cUL、UL、VDE - 额定电压和电流:750V/17.5A(VDE)、300V/16A(cUL和UL) - 导线规格:AWG 22至AWG 12
13612.1 价格&库存
很抱歉,暂时无法提供与“13612.1”相匹配的价格&库存,您可以联系我们找货
