13696.4
13696.4
    CONTA-CLIP
    插件
    接线端子 插件
13696.4 数据手册
Data sheet 13696.4 STL 130/2/10,16-V BK Male pin block, No. of poles: 2, Width: 15.24 mm, Colour: Black RAL: 9005 Business data Article number 13696.4 Article name STL 130/2/10,16-V BK GTIN (EAN) 4044211087098 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 0.4 g Weight per piece (including packaging) 0.5 g Unit of weight G Customs number 85366930 Country of origin QU Colour Black Creation date 15.12.2023 11:35:27 Subject to technical changes 1 Data sheet 13696.4 STL 130/2/10,16-V BK Technical data Dimensions Length 2.8 mm Length of the pin 3.5 mm Width 15.24 mm Width left 2.54 mm Width right 2.54 mm Height 9 mm Drill hole diameter 1.5 mm Diameter of connecting pin 1.3 mm Pitch 10.16 mm Ratings Rated voltage 630 V Rated current 7A Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 2 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Brass Creation date 15.12.2023 11:35:27 Subject to technical changes 2 Data sheet 13696.4 STL 130/2/10,16-V BK Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 11:35:27 Subject to technical changes 3 Data sheet 13696.4 STL 130/2/10,16-V BK Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup C: rated voltage 150 V cUL Usegroup C: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup C: rated voltage 150 V UL Usegroup C: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 630 V VDE rated current 7A VDE rated impulse voltage 6 kV VDE overvoltage category III VDE contamination degree 3 Creation date 15.12.2023 11:35:27 Subject to technical changes 4 Data sheet 13696.4 STL 130/2/10,16-V BK Media Creation date 15.12.2023 11:35:27 Subject to technical changes 5 Data sheet 13696.4 STL 130/2/10,16-V BK Accessories Creation date 15.12.2023 11:35:27 Subject to technical changes 6
13696.4
物料型号为13696.4 STL 130/2/10,16-V BK。
这是一个2针男性端子块,宽度为15.24毫米,颜色为黑色。
技术数据包括长度2.8毫米,针长3.5毫米,高度9毫米,钻孔直径1.5毫米,连接针直径1.3毫米,间距10.16毫米。
额定电压为630V,额定电流为7A,额定脉冲电压为6kV。
材料方面,绝缘体由聚酰胺6.6制成,阻燃等级为UL94 V-0,工作温度范围从-30°C至105°C,接触针材料为黄铜。
存储温度范围从-40°C至105°C,绝缘电阻为110^13欧姆x厘米,CTI为600,GWFI为850,GWFI后辉光时间为30秒,GWIT为775°C,GWIT暴露时间为5秒。
根据标准,插拔周期为100次,推荐的波峰焊接温度为265°C,最短焊接持续时间为3秒,最长为4秒。
产品符合REACH和RoHS标准。
认证包括cUL认可,CSA 22.2 No. 158,UL认可UL1059,VDE批准DIN EN61984。
13696.4 价格&库存
很抱歉,暂时无法提供与“13696.4”相匹配的价格&库存,您可以联系我们找货
