Data sheet
13697.4 STL 130/3/10,16-V BK
Male pin block, No. of poles: 3, Width: 25.4 mm, Colour: Black
RAL: 9005
Business data
Article number
13697.4
Article name
GTIN (EAN)
4044211087104
Connector version
Attached plug-in connector
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
0.6 g
Weight per piece (including packaging)
1.07 g
Unit of weight
G
Customs number
85366930
Country of origin
QU
Colour
Black
Creation date 16.12.2023 20:03:03
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
2.8 mm
Length of the pin
3.5 mm
Width
25.4 mm
Width left
2.54 mm
Width right
2.54 mm
Height
9 mm
Drill hole diameter
1.5 mm
Diameter of connecting pin
1.3 mm
Pitch
10.16 mm
Ratings
Rated voltage
630 V
Rated current
7A
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Connection data
Angle of PCB/contact
90° (vertically upwards)
Number of plug-in rows
1
No. of poles
3
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Contact pin
Brass
2
Data sheet
Technical data
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Plug-in cycles acc. to standard
100
Recommended wave soldering temperature
265 °C
Recommended wave soldering duration, min.
3 Sek.
Recommended wave soldering duration, max.
4 Sek.
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
10 A
cUL Usegroup C: rated voltage
150 V
cUL Usegroup C: rated current
10 A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
10 A
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
10 A
150 V
10 A
300 V
10 A
UL wire material
Cu
UL factory wiring
1
UL Recognized
1
VDE approval
VDE approval
DIN EN 61984
VDE approval granted
yes
VDE rated voltage
630 V
VDE rated current
7A
VDE rated impulse voltage
6 kV
VDE overvoltage category
III
VDE contamination degree
3
4
Data sheet
Media
5
Data sheet
Accessories
6
很抱歉,暂时无法提供与“13697.4”相匹配的价格&库存,您可以联系我们找货
