Data sheet
13726.1 PKB 1550/11/3,50-F GN
Female socket block, Screw connection, No. of poles: 11, Width: 48.9 mm, Colour: Green
Business data
Article number
13726.1
Article name
GTIN (EAN)
4044211087395
Connector version
Free connector
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
7.7 g
Weight per piece (including packaging)
8.5 g
Unit of weight
G
Customs number
85366930
Country of origin
QU
Colour
Green
Creation date 16.12.2023 20:02:58
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
11.1 mm
Width
48.9 mm
Width left
6.95 mm
Width right
6.95 mm
Height
15.5 mm
Pitch
3.5 mm
Ratings
Rated voltage
160 V
Rated current
8A
Rated cross-section
1.5 mm²
Rated impulse voltage
2.5 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Screw connection
Angle of wire connection/contact
0°/180° (horizontal)
Number of plug-in rows
1
No. of poles
11
Contact version
Female connector
Wire cross-section single-core (rigid) / stranded, min.
0.14 mm²
Wire cross-section single core (rigid)/stranded, max.
1.5 mm²
Wire cross-section stranded, min.
0.14 mm²
Wire cross-section stranded, max.
1.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.25 mm²
max.
1 mm²
Wire cross-section AWG, min.
28
Wire cross-section AWG, max.
16
Stripping length
7 mm
Screw threading
M2
Torque
0.25 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Clamping element
Brass
Contact spring
Bronze
Screws
Bronze
Flange screws
Steel
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
5
Plug-in cycles acc. to standard
100
Environmental Product Compliance
REACH Conform
No
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
REACH CAS 1 Substance
LEAD
REACH CAS 1 Percent minimal
0.1 %
REACH CAS 1 Percent maximum
4%
REACH CAS 1 Number
7439-92-1
RoHS Conform
yes
RoHS Exception rule
6c
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
8A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
8A
cUL wire cross-section single-core (rigid) AWG, min.
28
cUL wire cross-section single-core (rigid) AWG, max. 16
cUL wire cross-section stranded AWG, min.
28
cUL wire cross-section stranded AWG, max.
16
cUL torque
0.25 Nm
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
8A
300 V
8A
28
16
28
16
UL torque
2.21 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
4
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 61984
VDE approval granted
yes
VDE rated voltage
160 V
VDE rated current
8A
VDE rated current wire cross-section rigid, min.
6A
VDE rated current wire cross-section rigid, max.
8A
VDE rated current wire cross-section stranded, min.
6A
VDE rated current wire cross-section stranded, max.
8A
VDE rated impulse voltage
2.5 kV
VDE wire cross-section rigid, min.
0.5 mm²
VDE wire cross-section rigid, max.
1.5 mm²
VDE wire cross-section stranded, min.
0.5 mm²
VDE wire cross-section stranded, max.
1.5 mm²
VDE screw threading
M2
VDE torque
0.25 Nm
VDE overvoltage category
III
VDE contamination degree
3
5
Data sheet
Media
6
Data sheet
Accessories
7
很抱歉,暂时无法提供与“13726.1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+58.70880
- 200+22.72320
- 500+21.92400
- 1000+21.53520
