Data sheet
1390.3 TRK 1,5 OG
Disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 2.5 mm², Width: 6 mm, Colour: Orange
Business data
Article number
1390.3
Article name
TRK 1,5 OG
GTIN (EAN)
4044211044329
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
10.2 g
Weight per piece (including packaging)
10.73 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Prio-Article
1390.2
Product description
Disconnect terminal
Creation date 17.12.2023 17:20:36
Subject to technical changes
1
Data sheet
1390.3 TRK 1,5 OG
Technical data
Dimensions
Length
48 mm
Width
6 mm
Height TS 35/7.5
48.3 mm
Height TS 32
52.8 mm
Ratings
Rated voltage
400 V
Rated current
10 A
Rated cross-section
2.5 mm²
Rated impulse voltage
4 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
0.32 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
12
Stripping length
8 mm
Screw head
Slotted
Screw threading
M3
Tightening torque, min.
0.5 Nm
Tightening torque, max.
1 Nm
2
Data sheet
1390.3 TRK 1,5 OG
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Gauge plug acc. to EN 60 947-1
A4
End plate required
Version of lengthwise partition
Swivelling
Environmental Product Compliance
REACH Candidate Substance Note
No
3
Data sheet
1390.3 TRK 1,5 OG
Approvals
Standards and regulations
Nemko approval
EN 60947-7-1:2005
Nemko approval granted
yes
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup B: rated voltage
600 V
cUL Usegroup B: rated current
15 A
cUL Usegroup C: rated voltage
600 V
cUL Usegroup C: rated current
15 A
cUL wire cross-section single-core (rigid) AWG, min.
22
cUL wire cross-section single-core (rigid) AWG, max. 12
cUL wire cross-section stranded AWG, min.
22
cUL wire cross-section stranded AWG, max.
12
cUL torque
7 Nm
cUL wire material
Cu
cUL Recognized
1
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
400 V
KEMA rated current
10 A
KEMA rated impulse voltage
4 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
1390.3 TRK 1,5 OG
Approvals
UL Recognized
UL approval
UL 1059
600 V
15 A
600 V
15 A
22
12
22
12
UL torque
7 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
5
Data sheet
1390.3 TRK 1,5 OG
Media
6
Data sheet
1390.3 TRK 1,5 OG
Accessories
Insulated external cross-connector
External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 16.9
mm, Rated current: 27 A; Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2065.0
AQI 3/6/17 YE
4044211048716
50 ST
External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 23
Article number
Article name
GTIN (EAN)
Packaging
unit
2066.0
AQI 4/6/17 YE
4044211048723
50 ST
External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 10.8
Article number
Article name
GTIN (EAN)
Packaging
unit
2064.0
AQI 2/6/17 YE
4044211048709
50 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
9323.7
PMC SB 8/40 WH
4044211129231
400 ST
7
Data sheet
1390.3 TRK 1,5 OG
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1086.0
SDB 0,6x3,5
4044211014797
1 ST
8
