13908.4
13908.4
    CONTA-CLIP
    P=3.5mm
    接线端子 间距:3.50mm 自由悬挂
13908.4 数据手册
Data sheet 13908.4 PKB 1350/10/3,50 DG Female socket block, Wire protection, No. of poles: 10, Width: 35 mm, Colour: Dark grey Business data Article number 13908.4 Article name PKB 1350/10/3,50 DG GTIN (EAN) 4044211136154 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 5.63 g Weight per piece (including packaging) 6.33 g Unit of weight G Customs number 85366930 Country of origin TN Colour Dark grey Creation date 14.12.2023 18:10:00 Subject to technical changes 1 Data sheet 13908.4 PKB 1350/10/3,50 DG Technical data Dimensions Length 9.5 mm Width 35 mm Width left 1.75 mm Width right 1.75 mm Height 10 mm Pitch 3.5 mm Ratings Rated voltage 125 V Rated current 8A Rated cross-section 1.5 mm² Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Wire protection Angle of wire connection/contact 270° (vertically downwards) Number of plug-in rows 1 No. of poles 10 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.08 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.08 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 0.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 16 Stripping length 5 mm Screw threading M2 Torque 0.25 Nm Creation date 14.12.2023 18:10:00 Subject to technical changes 2 Data sheet 13908.4 PKB 1350/10/3,50 DG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Contact spring Bronze Screws Bronze Wire protection Stainless steel Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 14.12.2023 18:10:00 Subject to technical changes 3 Data sheet 13908.4 PKB 1350/10/3,50 DG Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 150 V cUL Usegroup B: rated current 9A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 16 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 16 cUL torque 0.25 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 150 V UL Usegroup B: rated current 9A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 16 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 16 UL torque 2.21 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 14.12.2023 18:10:00 Subject to technical changes 4 Data sheet 13908.4 PKB 1350/10/3,50 DG Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 125 V VDE rated current 8A VDE rated current wire cross-section rigid, min. 4A VDE rated current wire cross-section rigid, max. 8A VDE rated current wire cross-section stranded, min. 4A VDE rated current wire cross-section stranded, max. 8A VDE rated impulse voltage 2.5 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 1.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 1.5 mm² VDE screw threading M2 VDE torque 0.25 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 18:10:00 Subject to technical changes 5 Data sheet 13908.4 PKB 1350/10/3,50 DG Media Creation date 14.12.2023 18:10:00 Subject to technical changes 6 Data sheet 13908.4 PKB 1350/10/3,50 DG Accessories Creation date 14.12.2023 18:10:00 Subject to technical changes 7
13908.4 价格&库存
很抱歉,暂时无法提供与“13908.4”相匹配的价格&库存,您可以联系我们找货
