13921.4
13921.4
    CONTA-CLIP
    插件
    接线端子 插件
13921.4 数据手册
Data sheet 13921.4 STL 1350/12/3,50-V BK Male pin block, No. of poles: 12, Width: 42 mm, Colour: Black RAL: 9005 Business data Article number 13921.4 Article name STL 1350/12/3,50-V BK GTIN (EAN) 4044211136284 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 1.25 g Weight per piece (including packaging) 1.75 g Unit of weight G Customs number 85366930 Country of origin QU Colour Black Creation date 16.12.2023 20:12:20 Subject to technical changes 1 Data sheet 13921.4 STL 1350/12/3,50-V BK Technical data Dimensions Length 2.7 mm Length of the pin 3.5 mm Width 42 mm Width left 1.75 mm Width right 1.75 mm Height 9 mm Drill hole diameter 1.3 mm Diameter of connecting pin 1 mm Pitch 3.5 mm Ratings Rated voltage 125 V Rated current 8A Rated impulse voltage 2.5 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 12 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Brass Creation date 16.12.2023 20:12:20 Subject to technical changes 2 Data sheet 13921.4 STL 1350/12/3,50-V BK Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^15 Ohm x cm Creepage-current resistance CTI 175 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:12:20 Subject to technical changes 3 Data sheet 13921.4 STL 1350/12/3,50-V BK Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 150 V cUL Usegroup B: rated current 9A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 150 V UL Usegroup B: rated current 9A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 125 V VDE rated current 8A VDE rated impulse voltage 2.5 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 20:12:20 Subject to technical changes 4 Data sheet 13921.4 STL 1350/12/3,50-V BK Media Creation date 16.12.2023 20:12:20 Subject to technical changes 5 Data sheet 13921.4 STL 1350/12/3,50-V BK Accessories Creation date 16.12.2023 20:12:20 Subject to technical changes 6
13921.4 价格&库存
很抱歉,暂时无法提供与“13921.4”相匹配的价格&库存,您可以联系我们找货
