1399.2
    CONTA-CLIP
    DISCONNECT TERMINAL
1399.2 数据手册
Data sheet 1399.2 TRK 1,5/STB BG Disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 2.5 mm², Width: 6 mm, Colour: Beige Business data Article number 1399.2 Article name TRK 1,5/STB BG GTIN (EAN) 4044211044466 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 9.4 g Weight per piece (including packaging) 10.04 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Disconnect terminal Colour Beige Creation date 16.12.2023 20:17:12 Subject to technical changes 1 Data sheet 1399.2 TRK 1,5/STB BG Technical data Dimensions Length 48 mm Width 6 mm Height TS 35/7.5 65 mm Height TS 32 70 mm Ratings Rated voltage 400 V Rated current 10 A Rated cross-section 2.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.32 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 8 mm Screw head Socket plug Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 16.12.2023 20:17:12 Subject to technical changes 2 Data sheet 1399.2 TRK 1,5/STB BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A4 End plate required Built-in test socket available Version of lengthwise partition Pluggable Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 20:17:12 Subject to technical changes 3 Data sheet 1399.2 TRK 1,5/STB BG Approvals cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 15 A cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 15 A cUL wire cross-section single-core (rigid) AWG, min. 22 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 22 cUL wire cross-section stranded AWG, max. 12 cUL torque 7 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 15 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 15 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 20:17:12 Subject to technical changes 4 Data sheet 1399.2 TRK 1,5/STB BG Media Creation date 16.12.2023 20:17:12 Subject to technical changes 5 Data sheet 1399.2 TRK 1,5/STB BG Accessories Insulated external cross-connector External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 16.9 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2065.0 AQI 3/6/17 YE 4044211048716 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 23 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2066.0 AQI 4/6/17 YE 4044211048723 50 ST External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 10.8 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2064.0 AQI 2/6/17 YE 4044211048709 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Test plug Test plug, Colour: Red Article number Article name GTIN (EAN) Packaging unit 2007.0 PS 2,3 4044211048105 20 ST Creation date 16.12.2023 20:17:12 Subject to technical changes 6 Data sheet 1399.2 TRK 1,5/STB BG Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Disconnect plug Disconnect plug with diode 1N4007, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1401.2 DS 2/TRK 1,5 YE 4044211044480 50 ST Disconnect plug with diode 1N4007, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1402.2 DS 3/TRK 1,5 YE 4044211044497 50 ST Disconnect plug with wire bridge, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1400.2 DS 1/TRK 1,5 YE 4044211044473 50 ST Disconnect plug unpopulated, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1403.2 DS 4/TRK 1,5 YE 4044211044503 50 ST Creation date 16.12.2023 20:17:12 Subject to technical changes 7 Data sheet 1399.2 TRK 1,5/STB BG ##INVERSE##CONTA-CONNECT Disconnect plug with diode 1N4007, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1401.2 DS 2/TRK 1,5 YE 4044211044480 50 ST Disconnect plug with diode 1N4007, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1402.2 DS 3/TRK 1,5 YE 4044211044497 50 ST Disconnect plug with wire bridge, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1400.2 DS 1/TRK 1,5 YE 4044211044473 50 ST Disconnect plug unpopulated, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 1403.2 DS 4/TRK 1,5 YE 4044211044503 50 ST Creation date 16.12.2023 20:17:12 Subject to technical changes 8
1399.2 价格&库存
很抱歉,暂时无法提供与“1399.2”相匹配的价格&库存,您可以联系我们找货
  • 100+27.67274100+3.46241
