1409.2
1409.2
    CONTA-CLIP
    EX-FEED-THROUGH TERMINAL CERTIFI
1409.2 数据手册
Data sheet 1409.2 RK 16/35 N Ex BG Ex feed-through terminal ATEX-certified, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 11.9 mm, Colour: Beige Business data Article number 1409.2 Article name RK 16/35 N Ex BG GTIN (EAN) 4044211107871 Explosion-proof version (EEx e) yes Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 27 g Weight per piece (including packaging) 28.44 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1409.2 Product description Ex feed-through terminal ATEX-certified Creation date 16.12.2023 18:47:44 Subject to technical changes 1 Data sheet 1409.2 RK 16/35 N Ex BG Technical data Dimensions Length 54 mm Width 11.9 mm Height TS 35/7.5 47 mm Ratings Rated voltage 500 V Rated current 76 A Rated cross-section 16 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.43 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 2.5 mm² Wire cross-section single core (rigid)/stranded, max. 25 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 2.5 mm² Wire cross-section stranded with wire-end ferrules, max. 16 mm² Wire cross-section AWG, min. 12 Wire cross-section AWG, max. 4 Stripping length 15 mm Screw head Slotted Screw threading M5 Tightening torque, min. 2 Nm Tightening torque, max. 4 Nm Creation date 16.12.2023 18:47:44 Subject to technical changes 2 Data sheet 1409.2 RK 16/35 N Ex BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 B7 Number of cross-connection channels 1 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 18:47:44 No Subject to technical changes 3 Data sheet 1409.2 RK 16/35 N Ex BG Approvals Standards and regulations ATEX certification number TÜV ATEX 7092U EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 85 A CSA wire cross-section AWG, min. 12 CSA wire cross-section AWG, max. 4 CSA stripping length 15 mm CSA File Number 042110_0_000 CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 85 A CSAus wire cross-section AWG, min. 12 CSAus wire cross-section AWG, max. 4 CSAus stripping length 15 mm CSAus File Number 042110_0_000 cUL Recognized cUL approval C22.2 No 158 cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 85 A cUL wire cross-section single-core (rigid) AWG, min. 10 cUL wire cross-section single-core (rigid) AWG, max. 4 cUL wire cross-section stranded AWG, min. 10 cUL wire cross-section stranded AWG, max. 4 cUL torque 20 Nm cUL wire material Cu cUL File Number E95701 cUL Recognized 1 Creation date 16.12.2023 18:47:44 Subject to technical changes 4 Data sheet 1409.2 RK 16/35 N Ex BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 76 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 2.5 mm² KEMA wire cross-section single-core (rigid), max. 25 mm² KEMA wire cross-section stranded, min. 2.5 mm² KEMA wire cross-section stranded, max. 16 mm² UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 85 A UL wire cross-section single-core (rigid) AWG, min. 10 UL wire cross-section single-core (rigid) AWG, max. 4 UL wire cross-section stranded AWG, min. 10 UL wire cross-section stranded AWG, max. 4 UL torque 20 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 16 mm² DNV GL rated current 76 A DNV GL rated voltage 800 V DNV GL test standard IEC 60947-7-1:2002 Creation date 16.12.2023 18:47:44 Subject to technical changes 5 Data sheet 1409.2 RK 16/35 N Ex BG Media Creation date 16.12.2023 18:47:44 Subject to technical changes 6 Data sheet 1409.2 RK 16/35 N Ex BG Accessories Cover Cover, Length: 26.5 mm, Width: 12 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 2967.0 AD 1/12/N WH 4044211056964 20 ST Cover, Length: 26.5 mm, Width: 12 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2955.0 AD 1/12/N/B YE 4044211056834 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 20.1 mm, Rated cross-section: 16 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2257.0 Q2 4044211050702 20 ST Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 115.3 mm, Rated cross-section: 16 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2266.0 Q 10 4044211050757 10 ST Creation date 16.12.2023 18:47:44 Subject to technical changes 7 Data sheet 1409.2 RK 16/35 N Ex BG Cross-connector Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 32 mm, Rated cross-section: 16 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2258.0 Q3 4044211050719 20 ST Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 43.9 mm, Rated cross-section: 16 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2265.0 Q4 4044211050740 10 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Creation date 16.12.2023 18:47:44 Subject to technical changes 8
1409.2 价格&库存
很抱歉,暂时无法提供与“1409.2”相匹配的价格&库存,您可以联系我们找货
