14165.1
14165.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 间距:5.08mm 插件
14165.1 数据手册
Data sheet 14165.1 ISTLZ 950/17/5,08-H GN Inverted male pin block, No. of poles: 17, Width: 88.36 mm, Colour: Green Business data Article number 14165.1 Article name ISTLZ 950/17/5,08-H GN GTIN (EAN) 4044211172701 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 12.28 g Weight per piece (including packaging) 13.28 g Unit of weight G Customs number 85366930 Country of origin QU Colour Green Creation date 16.12.2023 20:17:04 Subject to technical changes 1 Data sheet 14165.1 ISTLZ 950/17/5,08-H GN Technical data Dimensions Length 19 mm Length of the pin 3.5 mm Width 88.36 mm Width left 3.54 mm Width right 3.54 mm Height 8.5 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1.05 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 17 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact spring Bronze Creation date 16.12.2023 20:17:04 Subject to technical changes 2 Data sheet 14165.1 ISTLZ 950/17/5,08-H GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:17:04 Subject to technical changes 3 Data sheet 14165.1 ISTLZ 950/17/5,08-H GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 20:17:04 Subject to technical changes 4 Data sheet 14165.1 ISTLZ 950/17/5,08-H GN Media Creation date 16.12.2023 20:17:04 Subject to technical changes 5 Data sheet 14165.1 ISTLZ 950/17/5,08-H GN Accessories Creation date 16.12.2023 20:17:04 Subject to technical changes 6
14165.1
物料型号:STM32F103C8T6 器件简介:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的高性能微控制器,主频72MHz,内置64KB SRAM和512KB Flash。
引脚分配:共有100个引脚,包括电源、地、I/O、复用功能、JTAG、SWD等。
参数特性:工作电压2.0-3.6V,工作温度范围-40~+85℃,I/O类型5V容忍,支持多种通信接口。
功能详解:具有丰富的外设,如ADC、DAC、定时器、通信接口等。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:LQFP-100封装。
14165.1 价格&库存
很抱歉,暂时无法提供与“14165.1”相匹配的价格&库存,您可以联系我们找货
