14174.1
14174.1
    CONTA-CLIP
    插件,P=5.08mm
    接线端子 间距:5.08mm 插件
14174.1 数据手册
Data sheet 14174.1 ISTLZ 950/3/5,08-V GN Inverted male pin block, No. of poles: 3, Width: 17.24 mm, Colour: Green Business data Article number 14174.1 Article name ISTLZ 950/3/5,08-V GN GTIN (EAN) 4044211172800 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 2.41 g Weight per piece (including packaging) 2.91 g Unit of weight G Customs number 85366930 Country of origin TW Colour Green Creation date 14.12.2023 19:09:32 Subject to technical changes 1 Data sheet 14174.1 ISTLZ 950/3/5,08-V GN Technical data Dimensions Length 8.5 mm Length of the pin 3.5 mm Width 17.24 mm Width left 3.54 mm Width right 3.54 mm Height 19 mm Drill hole diameter 1.4 mm Diameter of connecting pin 1.05 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 12 A Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 3 Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact spring Bronze Creation date 14.12.2023 19:09:32 Subject to technical changes 2 Data sheet 14174.1 ISTLZ 950/3/5,08-V GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 19:09:32 Subject to technical changes 3 Data sheet 14174.1 ISTLZ 950/3/5,08-V GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 12 A VDE rated impulse voltage 4 kV VDE overvoltage category III VDE contamination degree 3 Creation date 14.12.2023 19:09:32 Subject to technical changes 4 Data sheet 14174.1 ISTLZ 950/3/5,08-V GN Media Creation date 14.12.2023 19:09:32 Subject to technical changes 5 Data sheet 14174.1 ISTLZ 950/3/5,08-V GN Accessories Creation date 14.12.2023 19:09:32 Subject to technical changes 6
14174.1 价格&库存
很抱歉,暂时无法提供与“14174.1”相匹配的价格&库存,您可以联系我们找货
