1420.2
1420.2
    CONTA-CLIP
    THREE-CONDUCTOR INSTALLATION TER
1420.2 数据手册
Data sheet 1420.2 DLI 2,5 L/N BG Three-wire installation terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 6 mm, Colour: Beige Business data Article number 1420.2 Article name DLI 2,5 L/N BG GTIN (EAN) 4044211044657 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 14.6 g Weight per piece (including packaging) 16.08 g Unit of weight G Customs number 85369010 Country of origin CZ Product description Three-wire installation terminals Colour Beige Creation date 16.12.2023 20:17:32 Subject to technical changes 1 Data sheet 1420.2 DLI 2,5 L/N BG Technical data Dimensions Length 90.5 mm Width 6 mm Height TS 35/7.5 53 mm Ratings Rated voltage 400 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.54 W Connection data Connection principle Screw connection Connection position Lateral Connections 4 Number of potentials 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 8 mm Screw head Slotted Screw threading M 2,5 Tightening torque, min. 0.4 Nm Tightening torque, max. 0.8 Nm N-function possible Creation date 16.12.2023 20:17:32 Subject to technical changes 2 Data sheet 1420.2 DLI 2,5 L/N BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 3 End plate required Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:17:32 Subject to technical changes 3 Data sheet 1420.2 DLI 2,5 L/N BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup B: rated voltage 300 V CSA Usegroup B: rated current 15 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 14 CSA stripping length 8 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup B: rated voltage 300 V CSAus Usegroup B: rated current 15 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 14 CSAus stripping length 8 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 24 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² KEMA torque, min. 0.4 Nm KEMA torque, max. 0.8 Nm Creation date 16.12.2023 20:17:32 Subject to technical changes 4 Data sheet 1420.2 DLI 2,5 L/N BG Media Creation date 16.12.2023 20:17:32 Subject to technical changes 5 Data sheet 1420.2 DLI 2,5 L/N BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2831.2 AP 2,5/D BG 4044211055561 20 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.6 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2833.0 Q3 4044211055585 50 ST Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 22.7 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2834.0 Q4 4044211055592 20 ST Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.3 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2835.0 Q 10 4044211055608 10 ST Creation date 16.12.2023 20:17:32 Subject to technical changes 6 Data sheet 1420.2 DLI 2,5 L/N BG Cross-connector Cross-connector, No. of poles: 20, Mounting type: Can be screwed on, Width: 120.3 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2836.0 Q 20 4044211055615 10 ST Cross-connector, No. of poles: 82, Mounting type: Screwable, Width: 500 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2154.0 Q 0,5 m/82 Pole 4044211049751 1 ST Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.5 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2832.0 Q2 4044211055578 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Insulation plate Creation date 16.12.2023 20:17:32 Subject to technical changes 7 Data sheet 1420.2 DLI 2,5 L/N BG Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2566.2 TRS 3 BG 4044211053567 100 ST Creation date 16.12.2023 20:17:32 Subject to technical changes 8
1420.2 价格&库存
很抱歉,暂时无法提供与“1420.2”相匹配的价格&库存,您可以联系我们找货
