Data sheet
14199.1 IPKBZ 950/5/5,08 GN
Inverted female socket block, Screw connection, No. of poles: 5, Width: 26.9 mm, Colour: Green
Business data
Article number
14199.1
Article name
IPKBZ 950/5/5,08 GN
GTIN (EAN)
4044211173067
Connector version
Free connector
Packaging unit
50
Quantity unit
PC
Packaging type
Carton
Type of banding
Without
Weight per piece (not including packaging)
8.18 g
Weight per piece (including packaging)
8.93 g
Unit of weight
G
Customs number
85366930
Country of origin
TW
Colour
Green
Creation date 16.12.2023 20:17:25
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
15 mm
Width
26.9 mm
Width left
3.29 mm
Width right
3.29 mm
Height
19.2 mm
Pitch
5.08 mm
Ratings
Rated voltage
250 V
Rated current
10 A
Rated cross-section
2.5 mm²
Rated impulse voltage
4 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Screw connection
Angle of wire connection/contact
0°/180° (horizontal)
Number of plug-in rows
1
No. of poles
5
Contact version
Female connector
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.25 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
28
Wire cross-section AWG, max.
12
Stripping length
7 mm
Screw threading
M3
Torque
0.5 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-30 °C
Working temperature, max.
105 °C
Clamping element
Brass
Contact pin
Brass
Screws
Steel
Further technical data
Storage temperature, min.
-40 °C
Storage temperature, max.
105 °C
Insulation resistance
1*10^13 Ohm x cm
Creepage-current resistance
CTI 600
Glow wire flammability index GWFI
GWFI 850
GWFI after-glow time
30 Sek.
Glow wire ignition temperature GWIT
GWIT 775 °C
GWIT exposure time
5 Sek.
Connection cycles, in compliance with standard
5
Plug-in cycles acc. to standard
100
Environmental Product Compliance
REACH Conform
No
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
REACH CAS 1 Substance
LEAD
REACH CAS 1 Percent minimal
0.1 %
REACH CAS 1 Percent maximum
4%
REACH CAS 1 Number
7439-92-1
RoHS Conform
yes
RoHS Exception rule
6c
3
Data sheet
Approvals
cUL Recognized
cUL approval
CSA 22.2 No.158
cUL Usegroup B: rated voltage
300 V
cUL Usegroup B: rated current
10 A
cUL Usegroup D: rated voltage
300 V
cUL Usegroup D: rated current
10 A
cUL wire cross-section single-core (rigid) AWG, min.
28
cUL wire cross-section single-core (rigid) AWG, max. 12
cUL wire cross-section stranded AWG, min.
28
cUL wire cross-section stranded AWG, max.
12
cUL torque
0.5 Nm
cUL wire material
Cu
cUL Recognized
1
UL Recognized
UL approval
UL 1059
300 V
10 A
300 V
10 A
28
12
28
12
UL torque
4.43 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
4
Data sheet
Approvals
VDE approval
VDE approval
DIN EN 61984
VDE approval granted
yes
VDE rated voltage
250 V
VDE rated current
10 A
VDE rated current wire cross-section rigid, min.
4A
VDE rated current wire cross-section rigid, max.
10 A
VDE rated current wire cross-section stranded, min.
4A
VDE rated current wire cross-section stranded, max.
10 A
VDE rated impulse voltage
4 kV
VDE wire cross-section rigid, min.
0.2 mm²
VDE wire cross-section rigid, max.
2.5 mm²
VDE wire cross-section stranded, min.
0.2 mm²
VDE wire cross-section stranded, max.
2.5 mm²
VDE screw threading
M3
VDE torque
0.5 Nm
VDE overvoltage category
III
VDE contamination degree
3
5
Data sheet
Media
6
Data sheet
Accessories
7
很抱歉,暂时无法提供与“14199.1”相匹配的价格&库存,您可以联系我们找货
