Data sheet
1422.2 DLI 2,5 N BG
Three-wire installation terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 2.5 mm², Width: 6 mm, Colour: Beige
Business data
Article number
1422.2
Article name
DLI 2,5 N BG
GTIN (EAN)
4044211044671
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
10.8 g
Weight per piece (including packaging)
12.12 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Product description
Three-wire installation terminals
Colour
Beige
Creation date 16.12.2023 09:03:05
Subject to technical changes
1
Data sheet
1422.2 DLI 2,5 N BG
Technical data
Dimensions
Length
90.5 mm
Width
6 mm
Height TS 35/7.5
53 mm
Ratings
Rated voltage
400 V
Rated current
24 A
Rated cross-section
2.5 mm²
Rated impulse voltage
4 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
0.77 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of potentials
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
14
Stripping length
8 mm
Screw head
Slotted
Screw threading
M 2,5
Tightening torque, min.
0.4 Nm
Tightening torque, max.
0.8 Nm
N-function possible
2
Data sheet
1422.2 DLI 2,5 N BG
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A3
Number of cross-connection channels
2
End plate required
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
1422.2 DLI 2,5 N BG
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup B: rated voltage
300 V
CSA Usegroup B: rated current
15 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
14
CSA stripping length
8 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup B: rated voltage
300 V
CSAus Usegroup B: rated current
15 A
CSAus wire cross-section AWG, min.
22
CSAus wire cross-section AWG, max.
14
CSAus stripping length
8 mm
4
Data sheet
1422.2 DLI 2,5 N BG
Media
5
Data sheet
1422.2 DLI 2,5 N BG
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2831.2
AP 2,5/D BG
4044211055561
20 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Cross-connector
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.6 mm,
Rated cross-section: 2.5 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2833.0
Q3
4044211055585
50 ST
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 22.7 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2834.0
Q4
4044211055592
20 ST
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2835.0
Q 10
4044211055608
10 ST
6
Data sheet
1422.2 DLI 2,5 N BG
Cross-connector
Cross-connector, No. of poles: 20, Mounting type: Can be screwed on, Width: 120.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2836.0
Q 20
4044211055615
10 ST
Cross-connector, No. of poles: 82, Mounting type: Screwable, Width: 500 mm, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
2154.0
Q 0,5 m/82 Pole
4044211049751
1 ST
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.5 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2832.0
Q2
4044211055578
50 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1085.0
SDB 0,5x3,0
4044211014643
1 ST
Insulation plate
7
Data sheet
1422.2 DLI 2,5 N BG
Insulation plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2566.2
TRS 3 BG
4044211053567
100 ST
8
