14264.1
14264.1
    CONTA-CLIP
    插件,P=7.62mm
    HEADER
14264.1 数据手册
Data sheet 14264.1 STLZ 965/2/7,62-H-F GN Male pin block, No. of poles: 2, Width: 25.82 mm, Colour: Green Business data Article number 14264.1 Article name STLZ 965/2/7,62-H-F GN GTIN (EAN) 4044211173715 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 2.78 g Weight per piece (including packaging) 3.28 g Unit of weight G Customs number 85366930 Country of origin TW Colour Green Creation date 16.12.2023 20:17:13 Subject to technical changes 1 Data sheet 14264.1 STLZ 965/2/7,62-H-F GN Technical data Dimensions Length 12 mm Width 25.82 mm Width left 9.1 mm Width right 9.1 mm Height 8.5 mm Drill hole diameter 1.6 mm Diameter of connecting pin 1 mm Pitch 7.62 mm Ratings Rated voltage 400 V Rated current 12 A Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 2 Materials Insulation housing Polybutylene terephthalate Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Brass Flange, threaded insert Brass Creation date 16.12.2023 20:17:13 Subject to technical changes 2 Data sheet 14264.1 STLZ 965/2/7,62-H-F GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance xx Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 16.12.2023 20:17:13 Subject to technical changes 3 Data sheet 14264.1 STLZ 965/2/7,62-H-F GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 400 V VDE rated current 12 A VDE rated impulse voltage 6 kV VDE overvoltage category III VDE contamination degree 3 Creation date 16.12.2023 20:17:13 Subject to technical changes 4 Data sheet 14264.1 STLZ 965/2/7,62-H-F GN Media Creation date 16.12.2023 20:17:13 Subject to technical changes 5 Data sheet 14264.1 STLZ 965/2/7,62-H-F GN Accessories Creation date 16.12.2023 20:17:13 Subject to technical changes 6
14264.1 价格&库存
很抱歉,暂时无法提供与“14264.1”相匹配的价格&库存,您可以联系我们找货
