1427.2
1427.2
    CONTA-CLIP
    EX-FEED-THROUGH TERMINAL CERTIFI
1427.2 数据手册
Data sheet 1427.2 RK 2,5-4 Ex BG Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Business data Article number 1427.2 Article name RK 2,5-4 Ex BG GTIN (EAN) 4044211044732 Explosion-proof version (EEx e) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 9.8 g Weight per piece (including packaging) 10.42 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1427.2 Product description Ex feed-through terminal ATEX-certified Creation date 16.12.2023 20:17:38 Subject to technical changes 1 Data sheet 1427.2 RK 2,5-4 Ex BG Technical data Dimensions Length 48 mm Width 6 mm Height TS 35/7.5 47 mm Height TS 32 51.5 mm Ratings Rated voltage 690 V Rated current 34 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.09 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 10 Stripping length 12 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 16.12.2023 20:17:38 Subject to technical changes 2 Data sheet 1427.2 RK 2,5-4 Ex BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:17:38 No Subject to technical changes 3 Data sheet 1427.2 RK 2,5-4 Ex BG Approvals Standards and regulations ATEX certification number NEMKO ATEX 1136 U EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 40 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 10 CSA stripping length 12 mm CSA torque, max. 1 Nm CSA torque, min. 0.5 Nm CSA File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² KEMA torque, min. 0.5 Nm KEMA torque, max. 1 Nm Creation date 16.12.2023 20:17:38 Subject to technical changes 4 Data sheet 1427.2 RK 2,5-4 Ex BG Approvals UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 30 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7.3 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 4 mm² DNV GL rated current 34 A DNV GL rated voltage 750 V DNV GL test standard IEC 60947-7-1:2002 Creation date 16.12.2023 20:17:38 Subject to technical changes 5 Data sheet 1427.2 RK 2,5-4 Ex BG Media Creation date 16.12.2023 20:17:38 Subject to technical changes 6 Data sheet 1427.2 RK 2,5-4 Ex BG Accessories Cover Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2494.0 AD 4/24/B/E YE 4044211052959 50 ST Cover, Length: 24 mm, Width: 24 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2011.0 AD 4/24/B YE 4044211048143 50 ST Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2493.0 AD 4/24/B/E YE 4044211052942 50 ST Cover, Length: 26.5 mm, Width: 6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2953.0 AD 1/6/B YE 4044211056810 50 ST Cover, Length: 26.5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 2965.0 AD 1/6 WH 4044211056940 50 ST Cover, Length: 24 mm, Width: 20 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2079.0 AD 4/24/B YE 4044211048877 50 ST End plate Creation date 16.12.2023 20:17:38 Subject to technical changes 7 Data sheet 1427.2 RK 2,5-4 Ex BG End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2001.2 AP 2,5-10 BG 4044211047979 50 End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 19.3 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2569.0 Q4 4044211053598 20 ST Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 49.9 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2570.0 Q 10 4044211053604 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 14.2 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2568.0 Q3 4044211053581 50 ST Creation date 16.12.2023 20:17:38 Subject to technical changes 8 Data sheet 1427.2 RK 2,5-4 Ex BG Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 9.1 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2567.0 Q2 4044211053574 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Test adapters Test adapter, Length: 37.3 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2812.0 TA 5/1/ST 4044211055394 10 ST Creation date 16.12.2023 20:17:38 Subject to technical changes 9 Data sheet 1427.2 RK 2,5-4 Ex BG Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2566.2 TRS 3 BG 4044211053567 100 ST Partition plate Partition plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2002.2 TW 2,5-10 BG 4044211048044 50 ##INVERSE##CONTA-CONNECT Test adapter, Length: 37.3 mm, Pitch size: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2813.0 TA 6/1/ST 4044211055400 10 ST Creation date 16.12.2023 20:17:38 Subject to technical changes 10
1427.2 价格&库存
很抱歉,暂时无法提供与“1427.2”相匹配的价格&库存,您可以联系我们找货
