14270.1
14270.1
    CONTA-CLIP
    插件,P=7.62mm
    接线端子 1x8P 间距:7.62mm 排数:1 每排Pin数:8
14270.1 数据手册
Data sheet 14270.1 STLZ 965/8/7,62-H-F GN Male pin block, No. of poles: 8, Width: 71.54 mm, Colour: Green Business data Article number 14270.1 Article name STLZ 965/8/7,62-H-F GN GTIN (EAN) 4044211173777 Connector version Attached plug-in connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 6.25 g Weight per piece (including packaging) 7g Unit of weight G Customs number 85366930 Country of origin TW Colour Green Creation date 15.12.2023 20:01:26 Subject to technical changes 1 Data sheet 14270.1 STLZ 965/8/7,62-H-F GN Technical data Dimensions Length 12 mm Width 71.54 mm Width left 9.1 mm Width right 9.1 mm Height 8.5 mm Drill hole diameter 1.6 mm Diameter of connecting pin 1 mm Pitch 7.62 mm Ratings Rated voltage 400 V Rated current 12 A Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Angle of PCB/contact 0°/180° (horizontal) Number of plug-in rows 1 No. of poles 8 Materials Insulation housing Polybutylene terephthalate Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Contact pin Brass Flange, threaded insert Brass Creation date 15.12.2023 20:01:26 Subject to technical changes 2 Data sheet 14270.1 STLZ 965/8/7,62-H-F GN Technical data Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance xx Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Plug-in cycles acc. to standard 100 Recommended wave soldering temperature 265 °C Recommended wave soldering duration, min. 3 Sek. Recommended wave soldering duration, max. 4 Sek. Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 15.12.2023 20:01:26 Subject to technical changes 3 Data sheet 14270.1 STLZ 965/8/7,62-H-F GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 10 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 10 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire material Cu UL factory wiring 1 UL Recognized 1 VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 400 V VDE rated current 12 A VDE rated impulse voltage 6 kV VDE overvoltage category III VDE contamination degree 3 Creation date 15.12.2023 20:01:26 Subject to technical changes 4 Data sheet 14270.1 STLZ 965/8/7,62-H-F GN Media Creation date 15.12.2023 20:01:26 Subject to technical changes 5 Data sheet 14270.1 STLZ 965/8/7,62-H-F GN Accessories Creation date 15.12.2023 20:01:26 Subject to technical changes 6
14270.1
物料型号: - 文章编号:14270.1 - 文章名称:STLZ 965/8/7,62-H-F GN - GTIN(EAN):4044211173777 - 连接器版本:附带插入式连接器 - 包装单位:50 - 数量单位:PC - 包装类型:纸箱 - 带类型:无 - 每件重量(不包括包装):6.25克 - 每件重量(包括包装):7克 - 重量单位:克 - 海关编号:85366930 - 原产国:TW - 颜色:绿色
器件简介: - 产品类型:公头针座块,8极 - 宽度:71.54毫米 - 颜色:绿色
引脚分配: - 长度:12毫米 - 宽度:71.54毫米 - 左侧宽度:9.1毫米 - 右侧宽度:9.1毫米 - 高度:8.5毫米 - 钻孔直径:1.6毫米 - 连接销直径:1毫米 - 间距:7.62毫米 - PCB/接触角度:0°/180°(水平) - 插入行数:1 - 极数:8
参数特性: - 额定电压:400V - 额定电流:12A - 额定脉冲电压:6kV - 过电压类别:= - 污染等级:3 - 工作温度范围:-30°C 至 105°C - 存储温度范围:-40°C 至 105°C - 绝缘电阻:110^13欧姆 x 厘米 - 爬电电流电阻:XX - 灼热丝可燃性指数GWFI:GWFI 850 - GWFI后辉光时间:30秒 - 灼热丝点燃温度GWIT:GWIT 775°C - GWIT暴露时间:5秒 - 插入循环次数:100次 - 推荐波峰焊接温度:265°C - 推荐波峰焊接时间:最小3秒,最大4秒
功能详解: - 环境产品合规性: - REACH合规:否 - REACH参考日期:2023-06-14 - REACH候选物质说明:否 - REACH CAS 1物质:铅 - REACH CAS 1最小百分比:0.1% - REACH CAS 1最大百分比:4% - REACH CAS 1编号:7439-92-1 - RoHS合规:是 - RoHS例外规则:6c
封装信息: - 绝缘体材料:聚对苯二甲酸丁二醇酯 - UL 94可燃性等级:V-0 - 接触销材料:黄铜 - 法兰、螺纹插入件材料:黄铜
14270.1 价格&库存
很抱歉,暂时无法提供与“14270.1”相匹配的价格&库存,您可以联系我们找货
