1428.2
1428.2
    CONTA-CLIP
    EX-DOUBLE-LEVEL TERMINAL CERTIFI
1428.2 数据手册
Data sheet 1428.2 RKD 2,5 Ex BG Ex double-level terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Business data Article number 1428.2 Article name RKD 2,5 Ex BG GTIN (EAN) 4044211044756 Explosion-proof version (EEx e) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 10.2 g Weight per piece (including packaging) 11 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1428.2 Product description Ex double-level terminal ATEX-certified Creation date 15.12.2023 05:10:13 Subject to technical changes 1 Data sheet 1428.2 RKD 2,5 Ex BG Technical data Dimensions Length 60.2 mm Width 5 mm Height TS 35/7.5 61 mm Height TS 32 65.5 mm Ratings Rated voltage 400 V Rated current 26 A Rated cross-section 2.5 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.66 W Connection data Connection principle Screw connection Connection position Lateral Connections 2x2 Number of terminals per level 2 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 14 Stripping length 7 mm Screw head Slotted Screw threading M 2,5 Tightening torque, min. 0.4 Nm Tightening torque, max. 0.8 Nm Creation date 15.12.2023 05:10:13 Subject to technical changes 2 Data sheet 1428.2 RKD 2,5 Ex BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 2 End plate required Number of test pick-off options 1 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 05:10:13 No Subject to technical changes 3 Data sheet 1428.2 RKD 2,5 Ex BG Approvals Standards and regulations ATEX certification number NEMKO ATEX 1136 U EAC approval TR ZU 004/2011 EAC approval granted yes KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 24 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 20 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 5.3 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 05:10:13 Subject to technical changes 4 Data sheet 1428.2 RKD 2,5 Ex BG Media Creation date 15.12.2023 05:10:13 Subject to technical changes 5 Data sheet 1428.2 RKD 2,5 Ex BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2101.2 AP 4 BG 4044211151652 20 Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2566.2 TRS 3 BG 4044211053567 100 ST Cross-connector Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 19.3 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2569.0 Q4 4044211053598 20 ST Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 49.9 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2570.0 Q 10 4044211053604 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 14.2 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2568.0 Q3 4044211053581 50 ST Creation date 15.12.2023 05:10:13 Subject to technical changes 6 Data sheet 1428.2 RKD 2,5 Ex BG Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 9.1 mm, Rated cross-section: 2.5 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2567.0 Q2 4044211053574 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Test adapters Test adapter, Length: 37.3 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2821.0 TAD 5/1/S 4044211055479 10 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1085.0 SDB 0,5x3,0 4044211014643 1 ST Creation date 15.12.2023 05:10:13 Subject to technical changes 7 Data sheet 1428.2 RKD 2,5 Ex BG Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST ##INVERSE##CONTA-CONNECT Test adapter, Length: 37.3 mm, Pitch size: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2821.0 TAD 5/1/S 4044211055479 10 ST Creation date 15.12.2023 05:10:13 Subject to technical changes 8
1428.2 价格&库存
很抱歉,暂时无法提供与“1428.2”相匹配的价格&库存,您可以联系我们找货
