14312.1
14312.1
    CONTA-CLIP
    P=5.08mm
    接线端子 间距:5.08mm 1x3P 自由悬挂
14312.1 数据手册
Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Female socket block, Screw connection, No. of poles: 3, Width: 25.4 mm, Colour: Green Business data Article number 14312.1 Article name PKBZ 1110/3/5,08-F GN GTIN (EAN) 4044211173487 Connector version Free connector Packaging unit 50 Quantity unit PC Packaging type Carton Type of banding Without Weight per piece (not including packaging) 6.1 g Weight per piece (including packaging) 6.6 g Unit of weight G Customs number 85366930 Country of origin TW Colour Green Creation date 15.12.2023 17:44:02 Subject to technical changes 1 Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Technical data Dimensions Length 12.6 mm Width 25.4 mm Width left 7.62 mm Width right 7.62 mm Height 26 mm Pitch 5.08 mm Ratings Rated voltage 250 V Rated current 10 A Rated cross-section 2.5 mm² Rated impulse voltage 4 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Angle of wire connection/contact 90° (vertically upwards) Number of plug-in rows 1 No. of poles 3 Contact version Female connector Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.25 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 28 Wire cross-section AWG, max. 12 Stripping length 7 mm Screw threading M3 Torque 0.5 Nm Creation date 15.12.2023 17:44:02 Subject to technical changes 2 Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -30 °C Working temperature, max. 105 °C Clamping element Brass Contact spring Bronze Screws Steel Further technical data Storage temperature, min. -40 °C Storage temperature, max. 105 °C Insulation resistance 1*10^13 Ohm x cm Creepage-current resistance CTI 600 Glow wire flammability index GWFI GWFI 850 GWFI after-glow time 30 Sek. Glow wire ignition temperature GWIT GWIT 775 °C GWIT exposure time 5 Sek. Connection cycles, in compliance with standard 5 Plug-in cycles acc. to standard 100 Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 15.12.2023 17:44:02 Subject to technical changes 3 Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Approvals cUL Recognized cUL approval CSA 22.2 No.158 cUL Usegroup B: rated voltage 300 V cUL Usegroup B: rated current 11 A cUL Usegroup D: rated voltage 300 V cUL Usegroup D: rated current 10 A cUL wire cross-section single-core (rigid) AWG, min. 28 cUL wire cross-section single-core (rigid) AWG, max. 12 cUL wire cross-section stranded AWG, min. 28 cUL wire cross-section stranded AWG, max. 12 cUL torque 0.5 Nm cUL wire material Cu cUL Recognized 1 UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 11 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 10 A UL wire cross-section single-core (rigid) AWG, min. 28 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 28 UL wire cross-section stranded AWG, max. 12 UL torque 4.43 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 17:44:02 Subject to technical changes 4 Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Approvals VDE approval VDE approval DIN EN 61984 VDE approval granted yes VDE rated voltage 250 V VDE rated current 10 A VDE rated current wire cross-section rigid, min. 6A VDE rated current wire cross-section rigid, max. 10 A VDE rated current wire cross-section stranded, min. 6A VDE rated current wire cross-section stranded, max. 10 A VDE rated impulse voltage 4 kV VDE wire cross-section rigid, min. 0.5 mm² VDE wire cross-section rigid, max. 2.5 mm² VDE wire cross-section stranded, min. 0.5 mm² VDE wire cross-section stranded, max. 2.5 mm² VDE screw threading M3 VDE torque 0.5 Nm VDE overvoltage category III VDE contamination degree 3 Creation date 15.12.2023 17:44:02 Subject to technical changes 5 Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Media Creation date 15.12.2023 17:44:02 Subject to technical changes 6 Data sheet 14312.1 PKBZ 1110/3/5,08-F GN Accessories Creation date 15.12.2023 17:44:02 Subject to technical changes 7
14312.1
物料型号: - 文章编号:14312.1 - 文章名称:PKBZ1110/3/5.08-F GN
器件简介: - 连接器类型:Female socket block(母头插座块) - 连接方式:Screw connection(螺丝连接) - 极数:3 - 宽度:25.4 mm - 颜色:Green(绿色)
引脚分配: - 接触版本:Female connector(母连接器) - 极数:3 - 线材截面积:单芯(刚性)/绞合,最小0.2mm²,最大4mm²
参数特性: - 额定电压:250V - 额定电流:10A - 额定截面积:2.5 mm² - 额定脉冲电压:4kV - 污染等级:3 - 连接原理:Screw connection(螺丝连接) - 导线连接/接触角度:90°(垂直向上) - 插入行数:1 - 线材截面积AWG,最小:28,最大:12 - 剥离长度:7 mm - 螺丝螺纹:M3 - 扭矩:0.5Nm
功能详解: - 绝缘材料:Polyamide 6.6(聚酰胺6.6) - 阻燃等级:UL 94 V-0 - 工作温度范围:-30°C 至 105°C - 夹紧元件:Brass(黄铜) - 接触弹簧:Bronze(青铜) - 螺丝:Steel(钢) - 绝缘电阻:110^13 Ohmcm - 爬电电流电阻:CTI600 - 灼热丝可燃性指数:GWFI 850 - 灼热丝点火温度:GWIT 775°C
应用信息: - 存储温度范围:-40°C 至 105°C - 连接循环次数:符合标准5次 - 插入循环次数:符合标准100次
封装信息: - 包装单位:50 - 单位:PC(件) - 包装类型:Carton(纸箱) - 重量:单件(不包括包装)6.1g,单件(包括包装)6.6g
认证信息: - cUL认证:CSA 22.2 No.158 - UL认证:UL1059 - VDE认证:DIN EN 61984
14312.1 价格&库存
很抱歉,暂时无法提供与“14312.1”相匹配的价格&库存,您可以联系我们找货
