1495.2
1495.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL
1495.2 数据手册
Data sheet 1495.2 RK 35/Z/IS BG Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated crosssection: 35 mm², Width: 16 mm, Colour: Beige Business data Article number 1495.2 Article name RK 35/Z/IS BG GTIN (EAN) 4044211045296 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 57.6 g Weight per piece (including packaging) 60.5 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 1495.2 Product description Feed-through terminal Creation date 16.12.2023 20:16:57 Subject to technical changes 1 Data sheet 1495.2 RK 35/Z/IS BG Technical data Dimensions Length 58 mm Width 16 mm Height TS 35/7.5 71.5 mm Height TS 32 76 mm Ratings Rated voltage 800 V Rated current 125 A Rated cross-section 35 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 4W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 2.5 mm² Wire cross-section single core (rigid)/stranded, max. 50 mm² Wire cross-section stranded, min. 2.5 mm² Wire cross-section stranded, max. 35 mm² Wire cross-section stranded with wire-end ferrules, min. 2.5 mm² Wire cross-section stranded with wire-end ferrules, max. 35 mm² Wire cross-section AWG, min. 12 Wire cross-section AWG, max. 2 Stripping length 20 mm Screw head Inner hex (Allen) Screw threading M6 Tightening torque, min. 2.5 Nm Tightening torque, max. 5 Nm Creation date 16.12.2023 20:16:57 Subject to technical changes 2 Data sheet 1495.2 RK 35/Z/IS BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 B9 Number of cross-connection channels 1 End plate required Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 20:16:57 No Subject to technical changes 3 Data sheet 1495.2 RK 35/Z/IS BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 100 A CSA wire cross-section AWG, min. 12 CSA wire cross-section AWG, max. 2 CSA stripping length 20 mm CSA torque, max. 5 Nm CSA torque, min. 2.5 Nm CSA File Number 042110_0_000 KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 125 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 2.5 mm² KEMA wire cross-section single-core (rigid), max. 50 mm² KEMA wire cross-section stranded, min. 2.5 mm² KEMA wire cross-section stranded, max. 35 mm² Creation date 16.12.2023 20:16:57 Subject to technical changes 4 Data sheet 1495.2 RK 35/Z/IS BG Approvals UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 110 A UL wire cross-section single-core (rigid) AWG, min. 12 UL wire cross-section single-core (rigid) AWG, max. 2 UL wire cross-section stranded AWG, min. 12 UL wire cross-section stranded AWG, max. 2 UL torque 22 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 German Lloyd approval DNV GL Certificate number TAE000014T DNV GL Location Classes Temperature: B, Humidity: B, Vibration: A DNV GL approval granted 1 DNV GL rated cross-section 35 mm² DNV GL rated current 135 A DNV GL rated voltage 750 V DNV GL test standard IEC 60947-7-1:2002 Creation date 16.12.2023 20:16:57 Subject to technical changes 5 Data sheet 1495.2 RK 35/Z/IS BG Media Creation date 16.12.2023 20:16:57 Subject to technical changes 6 Data sheet 1495.2 RK 35/Z/IS BG Accessories Cover Cover, Length: 38 mm, Width: 12.9 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2820.0 AD 1/16/B YE 4044211055462 20 ST Cover, Length: 37.3 mm, Width: 16 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 2970.0 AD 1/16 WH 4044211056995 20 ST End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2116.2 AP 35 BG 4044211049317 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Cross-connector Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 153 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2167.0 Q 10 4044211049898 10 ST Creation date 16.12.2023 20:16:57 Subject to technical changes 7 Data sheet 1495.2 RK 35/Z/IS BG Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 25 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2164.0 Q2 4044211049867 20 ST Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 57 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2166.0 Q4 4044211049881 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 41 mm, Rated cross-section: 35 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2165.0 Q3 4044211049874 20 ST Partition plate Partition plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2117.2 TW 35 BG 4044211049355 20 Creation date 16.12.2023 20:16:57 Subject to technical changes 8
1495.2 价格&库存
很抱歉,暂时无法提供与“1495.2”相匹配的价格&库存,您可以联系我们找货
