1497.5
1497.5
    CONTA-CLIP
    FEED-THROUGH TERMINAL FOR DIRECT
1497.5 数据手册
Data sheet 1497.5 BKA 10/1 BU Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Width: 8 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 1497.5 Article name BKA 10/1 BU GTIN (EAN) 4044211080983 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 11.4 g Weight per piece (including packaging) 12.06 g Unit of weight G Customs number 85369010 Prio-Article 1497.2 Product description Feed-through terminal for direct mount Creation date 15.12.2023 08:08:20 Subject to technical changes 1 Data sheet 1497.5 BKA 10/1 BU Technical data Dimensions Length 30 mm Width 8 mm Height 31 mm Pitch 8 mm Ratings Rated voltage 400 V Rated current 57 A Rated cross-section 10 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.82 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 10 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 8 Stripping length 10 mm Screw head Slotted Screw threading M4 Tightening torque, min. 1.2 Nm Tightening torque, max. 2 Nm Creation date 15.12.2023 08:08:20 Subject to technical changes 2 Data sheet 1497.5 BKA 10/1 BU Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A5 End plate required Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 08:08:20 No Subject to technical changes 3 Data sheet 1497.5 BKA 10/1 BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 57 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 8 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 57 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 8 CSAus stripping length 10 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 57 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 10 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 10 mm² KEMA torque, min. 1.2 Nm KEMA torque, max. 2 Nm Creation date 15.12.2023 08:08:20 Subject to technical changes 4 Data sheet 1497.5 BKA 10/1 BU Media Creation date 15.12.2023 08:08:20 Subject to technical changes 5 Data sheet 1497.5 BKA 10/1 BU Accessories Insulated external cross-connector External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2067.0 AQI 2/8/11 YE 4044211048730 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2069.0 AQI 4/8/11 YE 4044211048754 50 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2068.0 AQI 3/8/11 YE 4044211048747 50 ST End support End support, Mounting type: Mounting rail TS 35/7.5, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2946.2 EH 35 BG 4044211056735 50 ST End support, Mounting type: Mounting surface, Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2939.2 EH 3 BG 4044211056643 20 Quick marking Creation date 15.12.2023 08:08:20 Subject to technical changes 6 Data sheet 1497.5 BKA 10/1 BU Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Creation date 15.12.2023 08:08:20 Subject to technical changes 7
1497.5 价格&库存
很抱歉,暂时无法提供与“1497.5”相匹配的价格&库存,您可以联系我们找货
  • 100+14.10625100+1.82701
