Data sheet
1501.2 BKA 10/3 BG
Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Beige
Business data
Article number
1501.2
Article name
BKA 10/3 BG
GTIN (EAN)
4044211045609
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
39.6 g
Weight per piece (including packaging)
41.22 g
Unit of weight
G
Customs number
85369010
Country of origin
DE
Product description
Colour
Beige
Creation date 15.12.2023 03:39:30
Subject to technical changes
1
Data sheet
1501.2 BKA 10/3 BG
Technical data
Dimensions
Length
40.3 mm
Height
31 mm
Hole spacing (mid-point to mid-point)
32.3 mm
Pitch
8 mm
Ratings
Rated voltage
400 V
Rated current
57 A
Rated cross-section
10 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
1.82 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
6
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
10 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
10 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
10 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
8
Stripping length
10 mm
Screw head
Slotted
Screw threading
M4
Tightening torque, min.
1.2 Nm
Tightening torque, max.
2 Nm
2
Data sheet
1501.2 BKA 10/3 BG
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Mounting face
Gauge plug acc. to EN 60 947-1
A5
End plate required
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
1501.2 BKA 10/3 BG
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
300 V
CSA Usegroup C: rated current
57 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
8
CSA stripping length
10 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
300 V
CSAus Usegroup C: rated current
57 A
CSAus wire cross-section AWG, min.
22
CSAus wire cross-section AWG, max.
8
CSAus stripping length
10 mm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
400 V
KEMA rated current
57 A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
10 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
10 mm²
KEMA torque, min.
1.2 Nm
KEMA torque, max.
2 Nm
4
Data sheet
1501.2 BKA 10/3 BG
Media
5
Data sheet
1501.2 BKA 10/3 BG
Accessories
Insulated external cross-connector
External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1
mm, Rated current: 27 A; Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2067.0
AQI 2/8/11 YE
4044211048730
50 ST
External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3
Article number
Article name
GTIN (EAN)
Packaging
unit
2069.0
AQI 4/8/11 YE
4044211048754
50 ST
External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2
Article number
Article name
GTIN (EAN)
Packaging
unit
2068.0
AQI 3/8/11 YE
4044211048747
50 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
9323.7
PMC SB 8/40 WH
4044211129231
400 ST
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1087.0
SDB 0,8x4,0
4044211014803
1 ST
6
很抱歉,暂时无法提供与“1501.2”相匹配的价格&库存,您可以联系我们找货
