1503.2
1503.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL FOR DIRECT
1503.2 数据手册
Data sheet 1503.2 BKA 10/5 BG Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Beige Business data Article number 1503.2 Article name BKA 10/5 BG GTIN (EAN) 4044211045821 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 62.4 g Weight per piece (including packaging) 64.02 g Unit of weight G Customs number 85369010 Country of origin DE Product description Feed-through terminal for direct mount Colour Beige Creation date 14.12.2023 23:03:21 Subject to technical changes 1 Data sheet 1503.2 BKA 10/5 BG Technical data Dimensions Length 56.5 mm Height 31 mm Hole spacing (mid-point to mid-point) 48.5 mm Pitch 8 mm Ratings Rated voltage 400 V Rated current 57 A Rated cross-section 10 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.82 W Connection data Connection principle Screw connection Connection position Lateral Connections 10 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 10 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 10 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 10 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 8 Stripping length 10 mm Screw head Slotted Screw threading M4 Tightening torque, min. 1.2 Nm Tightening torque, max. 2 Nm Creation date 14.12.2023 23:03:21 Subject to technical changes 2 Data sheet 1503.2 BKA 10/5 BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A5 End plate required Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 23:03:21 Subject to technical changes 3 Data sheet 1503.2 BKA 10/5 BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 57 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 8 CSA stripping length 10 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 57 A CSAus wire cross-section AWG, min. 22 CSAus wire cross-section AWG, max. 8 CSAus stripping length 10 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 57 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 10 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 10 mm² KEMA torque, min. 1.2 Nm KEMA torque, max. 2 Nm Creation date 14.12.2023 23:03:21 Subject to technical changes 4 Data sheet 1503.2 BKA 10/5 BG Media Creation date 14.12.2023 23:03:21 Subject to technical changes 5 Data sheet 1503.2 BKA 10/5 BG Accessories Insulated external cross-connector External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2067.0 AQI 2/8/11 YE 4044211048730 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2069.0 AQI 4/8/11 YE 4044211048754 50 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2068.0 AQI 3/8/11 YE 4044211048747 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Creation date 14.12.2023 23:03:21 Subject to technical changes 6
1503.2 价格&库存
很抱歉,暂时无法提供与“1503.2”相匹配的价格&库存,您可以联系我们找货
