15301.2
    CONTA-CLIP
    INTERFACE MODULE
15301.2 数据手册
Data sheet 15301.2 SD-S 25CZ Interface module for D-SUB, Tension-spring connection and male D-SUB plug-in connector, Mounting type: Mounting rail TS 35, No. of poles: 25 Business data Article number 15301.2 Article name SD-S 25CZ GTIN (EAN) 4044211078720 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 66.5 g Weight per piece (including packaging) 129.9 g Unit of weight G Customs number 85369010 Country of origin NL Product description Interface module Creation date 15.12.2023 09:28:23 Subject to technical changes 1 Data sheet 15301.2 SD-S 25CZ Technical data Dimensions Length 47 mm Width 78 mm Height TS 35/7.5 38 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Tension-spring connection Number of connections 1 No. of poles 25 Wire cross-section single core (rigid), min. 0.08 mm² Wire cross-section single-core (rigid), max. 2.5 mm² Wire cross-section stranded, min. 0.14 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.14 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Stripping length 6 mm Input data Max. operating voltage AC/DC 125 V Current load per channel, max. 1,5 A Materials Working temperature, min. -20 °C Working temperature, max. 50 °C Further technical data Mounting type TS 35 Connector type D-sub male plug Test voltage 0.67 kV Shielded Creation date 15.12.2023 09:28:23 Subject to technical changes 2 Data sheet 15301.2 SD-S 25CZ Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 09:28:23 Subject to technical changes 3 Data sheet 15301.2 SD-S 25CZ Approvals Standards and regulations Standards / specifications Creation date 15.12.2023 09:28:23 DIN VDE 0110 / EN 50178 Subject to technical changes 4 Data sheet 15301.2 SD-S 25CZ Media Creation date 15.12.2023 09:28:23 Subject to technical changes 5 Data sheet 15301.2 SD-S 25CZ Accessories Creation date 15.12.2023 09:28:23 Subject to technical changes 6
15301.2 价格&库存
很抱歉,暂时无法提供与“15301.2”相匹配的价格&库存,您可以联系我们找货
  • 1+708.400011+88.17292
