Data sheet
15302.2 SD-B25C
Interface module for D-SUB, Screw connection and female D-SUB plug-in connector, Mounting type:
Mounting rail TS 35, No. of poles: 25
Business data
Article number
15302.2
Article name
SD-B25C
GTIN (EAN)
4044211047047
Packaging unit
1
Quantity unit
PC
Weight per piece (not including packaging)
107.7 g
Weight per piece (including packaging)
171.5 g
Unit of weight
G
Customs number
85369010
Country of origin
NL
Product description
Interface module
Creation date 14.12.2023 18:42:46
Subject to technical changes
1
Data sheet
15302.2 SD-B25C
Technical data
Dimensions
Length
47 mm
Width
78 mm
Height TS 35/7.5
61 mm
Ratings
Overvoltage category
III
Contamination degree
2
Connection data
Connection principle
Screw connection
Number of connections
1
No. of poles
25
Wire cross-section single core (rigid), min.
0.2 mm²
Wire cross-section single-core (rigid), max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
2.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Stripping length
7 mm
Torque
0.6 Nm
Input data
Max. operating voltage AC/DC
125 V
Current load per channel, max.
1,5 A
Materials
Working temperature, min.
-20 °C
Working temperature, max.
50 °C
Further technical data
Mounting type
TS 35
Connector type
D-sub female socket block
Test voltage
0.67 kV
Shielded
2
Data sheet
15302.2 SD-B25C
Technical data
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
15302.2 SD-B25C
Approvals
Standards and regulations
Standards / specifications
DIN VDE 0110 / EN 50178
4
Data sheet
15302.2 SD-B25C
Media
5
Data sheet
15302.2 SD-B25C
Accessories
6
很抱歉,暂时无法提供与“15302.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1058.907691+137.25460
