1535.2
1535.2
    CONTA-CLIP
    EARTH TERMINAL
1535.2 数据手册
Data sheet 1535.2 SL 16/35/IS GNYE Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 12 mm, Colour: Green-yellow Business data Article number 1535.2 Article name SL 16/35/IS GNYE GTIN (EAN) 4044211047238 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 53 g Weight per piece (including packaging) 54.8 g Unit of weight G Customs number 85369010 Country of origin DE Product description Protective earth terminal Colour Green-yellow Creation date 16.12.2023 20:25:58 Subject to technical changes 1 Data sheet 1535.2 SL 16/35/IS GNYE Technical data Dimensions Length 50 mm Width 12 mm Height TS 35/7.5 58.5 mm Ratings Rated cross-section 35 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 2.5 mm² Wire cross-section single core (rigid)/stranded, max. 25 mm² Wire cross-section stranded, min. 2.5 mm² Wire cross-section stranded, max. 16 mm² Wire cross-section stranded with wire-end ferrules, min. 2.5 mm² Wire cross-section stranded with wire-end ferrules, max. 16 mm² Wire cross-section AWG, min. 10 Wire cross-section AWG, max. 4 Stripping length 15 mm Screw head Inner hex (Allen) Screw threading M5 Tightening torque, min. 2 Nm Tightening torque, max. 4 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Creation date 16.12.2023 20:25:58 Subject to technical changes 2 Data sheet 1535.2 SL 16/35/IS GNYE Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 B7 Number of cross-connection channels 1 Tightening torque, fastening screw max. 2.4 Nm Tightening torque, fastening screw min. 1.2 Nm Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:25:58 Subject to technical changes 3 Data sheet 1535.2 SL 16/35/IS GNYE Approvals Standards and regulations EAC approval TR ZU 004/2013 EAC approval granted yes Nemko approval EN 60947-7-2:2002 Nemko approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA wire cross-section AWG, min. 12 CSA wire cross-section AWG, max. 6 CSA stripping length 15 mm CSA File Number 042110_0_000 CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus wire cross-section AWG, min. 12 CSAus wire cross-section AWG, max. 6 CSAus stripping length 15 mm CSAus File Number 042110_0_000 cUL Recognized cUL approval C22.2 No 158 cUL wire cross-section single-core (rigid) AWG, min. 10 cUL wire cross-section single-core (rigid) AWG, max. 4 cUL wire cross-section stranded AWG, min. 10 cUL wire cross-section stranded AWG, max. 4 cUL torque 20 Nm cUL wire material Cu cUL File Number E95701 cUL Recognized 1 Creation date 16.12.2023 20:25:58 Subject to technical changes 4 Data sheet 1535.2 SL 16/35/IS GNYE Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 1.5 mm² KEMA wire cross-section single-core (rigid), max. 25 mm² KEMA wire cross-section stranded, min. 1.5 mm² KEMA wire cross-section stranded, max. 16 mm² UL Recognized UL approval UL 1059 UL wire cross-section single-core (rigid) AWG, min. 10 UL wire cross-section single-core (rigid) AWG, max. 4 UL wire cross-section stranded AWG, min. 10 UL wire cross-section stranded AWG, max. 4 UL torque 20 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL File Number E95701 UL Recognized 1 Creation date 16.12.2023 20:25:58 Subject to technical changes 5 Data sheet 1535.2 SL 16/35/IS GNYE Media Creation date 16.12.2023 20:25:58 Subject to technical changes 6 Data sheet 1535.2 SL 16/35/IS GNYE Accessories Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1087.0 SDB 0,8x4,0 4044211014803 1 ST Creation date 16.12.2023 20:25:58 Subject to technical changes 7
1535.2 价格&库存
很抱歉,暂时无法提供与“1535.2”相匹配的价格&库存,您可以联系我们找货
