1538.2
1538.2
    CONTA-CLIP
    EARTH TERMINAL
1538.2 数据手册
Data sheet 1538.2 SL 35/35/N/IS GNYE Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 35 mm², Width: 16 mm, Colour: Green-yellow Business data Article number 1538.2 Article name SL 35/35/N/IS GNYE GTIN (EAN) 4044211047276 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 99.8 g Weight per piece (including packaging) 103.25 g Unit of weight G Customs number 85369010 Country of origin DE Product description Protective earth terminal Colour Green-yellow Creation date 16.12.2023 20:26:11 Subject to technical changes 1 Data sheet 1538.2 SL 35/35/N/IS GNYE Technical data Dimensions Length 58 mm Width 16 mm Height TS 35/7.5 71.5 mm Ratings Rated cross-section 35 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 2.5 mm² Wire cross-section single core (rigid)/stranded, max. 50 mm² Wire cross-section stranded, min. 2.5 mm² Wire cross-section stranded, max. 35 mm² Wire cross-section stranded with wire-end ferrules, min. 2.5 mm² Wire cross-section stranded with wire-end ferrules, max. 35 mm² Wire cross-section AWG, min. 12 Wire cross-section AWG, max. 2 Stripping length 20 mm Screw head Inner hex (Allen) Screw threading M6 Tightening torque, min. 2.5 Nm Tightening torque, max. 5 Nm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Creation date 16.12.2023 20:26:11 Subject to technical changes 2 Data sheet 1538.2 SL 35/35/N/IS GNYE Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 B9 Number of cross-connection channels 1 Tightening torque, fastening screw max. 4 Nm Tightening torque, fastening screw min. 2 Nm Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:26:11 Subject to technical changes 3 Data sheet 1538.2 SL 35/35/N/IS GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA wire cross-section AWG, min. 12 CSA wire cross-section AWG, max. 2 CSA stripping length 20 mm CSAus approval CSAus wire cross-section AWG, min. 12 CSAus wire cross-section AWG, max. 2 CSAus stripping length 20 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 2.5 mm² KEMA wire cross-section single-core (rigid), max. 50 mm² KEMA wire cross-section stranded, min. 2.5 mm² KEMA wire cross-section stranded, max. 35 mm² Creation date 16.12.2023 20:26:11 Subject to technical changes 4 Data sheet 1538.2 SL 35/35/N/IS GNYE Media Creation date 16.12.2023 20:26:11 Subject to technical changes 5 Data sheet 1538.2 SL 35/35/N/IS GNYE Accessories Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1088.0 SDB 1,2x6,5 4044211014810 1 ST Creation date 16.12.2023 20:26:11 Subject to technical changes 6
1538.2 价格&库存
很抱歉,暂时无法提供与“1538.2”相匹配的价格&库存,您可以联系我们找货
