15502.2
15502.2
    CONTA-CLIP
    SOCKETABLE
    PLUG RELAY
15502.2 数据手册
Data sheet 15502.2 PRC 1/24V DC Plug-in miniature power relay, With power contact, 1 CO contact, Input voltage: 24 VDC Business data Article number 15502.2 Article name PRC 1/24V DC GTIN (EAN) 4044211118143 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5g Weight per piece (including packaging) 6.6 g Unit of weight G Customs number 85364900 Country of origin ES Product description Plug-in relay Creation date 15.12.2023 17:46:37 Subject to technical changes 1 Data sheet 15502.2 PRC 1/24V DC Technical data Dimensions Length 28 mm Width 5 mm Height 15 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage 16,8-36 VDC - Holding current 0,4 Un - Drop-out voltage 0,05 Un Coil voltage 24 VDC - Power consumption 0,17 W Coil resistance 3390 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 1500 VA Electrical lifespan (AC1) 60x10³ Mechanical lifespan 10x10⁶ Contact load, min. 500 mW Bounce time at close of the NO/NC contact 3/8 ms Materials Contact material AgNi Working temperature, min. -40 °C Working temperature, max. 85 °C Further technical data Degree of protection RTIII (wash-tight) Insulation voltage coil/contact 4 kV Response/release time 12 / 5 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 10/5 g Shock resistance NO/NC 10/5 g Creation date 15.12.2023 17:46:37 Subject to technical changes 2 Data sheet 15502.2 PRC 1/24V DC Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 17:46:37 Subject to technical changes 3 Data sheet 15502.2 PRC 1/24V DC Approvals Standards and regulations CE compliant Creation date 15.12.2023 17:46:37 yes Subject to technical changes 4 Data sheet 15502.2 PRC 1/24V DC Media Creation date 15.12.2023 17:46:37 Subject to technical changes 5 Data sheet 15502.2 PRC 1/24V DC Accessories ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base IRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16190.2 IRC 6-12-24V AC/DC 4044211187262 10 ST Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16210.2 FIRC 6-12-24V AC/DC 4044211187453 10 ST Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16213.2 FIRCP 6-12-24V AC/DC 4044211187484 10 ST Interface-Relay-Compact (IRC) socket base FIRC I with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16221.2 FIRCI 6-12-24V AC/DC 4044211187569 10 ST Interface-Relay-Compact (IRC) socket base FIRC O with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16224.2 FIRCO 6-12-24V AC/DC 4044211187590 10 ST Interface-Relay-Compact (IRC) socket base IRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16193.2 IRCP 6-12-24V AC/DC 4044211187293 10 ST Creation date 15.12.2023 17:46:37 Subject to technical changes 6 Data sheet 15502.2 PRC 1/24V DC ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base IRCO with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16204.2 IRCO 6-12-24V AC/DC 4044211187415 10 ST Interface-Relay-Compact (IRC) socket base IRCI with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16201.2 IRCI 6-12-24V AC/DC 4044211187385 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base IRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16232.2 IRCU 1/24V AC/DC 4044211200169 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base IRCP... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16237.2 IRCPU 1/24V AC/DC 4044211200213 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base IRCO... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16252.2 IRCOU 1/24V AC/DC 4044211200077 10 ST Creation date 15.12.2023 17:46:37 Subject to technical changes 7 Data sheet 15502.2 PRC 1/24V DC ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) Complete, Consisting of base FIRC... with Push-In connection and pluggable miniature relay with power contact, Mounting type: Mountingrail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16262.2 FIRCU 1/24V AC/DC 4044211200411 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base FIRCP... with Push-In connection and pluggable miniature relay with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16267.2 FIRCPU 1/24V AC/DC 4044211200466 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base IRCI... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16247.2 IRCIU 1/24V AC/DC 4044211200312 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base FIRCI... with Push-In connection and pluggable miniature relay with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16277.2 FIRCIU 1/24V AC/DC 4044211200565 10 ST Interface-Relay-Compact (IRC) Complete, Consisting of base FIRCIO... with Push-In connection and pluggable miniature relay with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16282.2 FIRCOU 1/24V AC/DC 4044211200619 10 ST Creation date 15.12.2023 17:46:37 Subject to technical changes 8 Data sheet 15502.2 PRC 1/24V DC ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VDC Article number Article name GTIN (EAN) Packaging unit 15494.2 ZPRC 6-12-24V DC 4044211118341 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6.12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15488.2 PRC 6-12-24V AC/DC 4044211118228 10 ST Multifunction timing relay module, Interface Relay Compact (IRC) complete, Consisting of base MFR-IRCP with Screw connection and Plug-in miniature relay PRC with power contact, Mounting type: TS 35, 1 Changeover contact, Input voltage: 12 VAC / DC Article number Article name GTIN (EAN) Packaging unit 16256.2 MFR IRCPU 1/24V AC/DC 4044211200381 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15492.2 ZPRC 6-12-24V AC/DC 4044211118297 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15519.2 ZPRCU 1/24V AC/DC 4044211118587 10 ST Creation date 15.12.2023 17:46:37 Subject to technical changes 9 Data sheet 15502.2 PRC 1/24V DC ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15526.2 ZPRCU 1/24V DC 4044211118655 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15508.2 PRCU 1/24V AC/DC 4044211118471 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15515.2 PRCU 1/24V DC 4044211118549 10 ST Multi-function timing relay, Interface-Relay-Compact (IRC) socket base MFR-FIRCP with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16227.2 MFR FIRCP 12-24V AC/DC 4044211187620 10 ST Multifunction timing relay module, Interface Relay Compact (IRC) complete, Consisting of base MFR-IRCP with Screw connection and Plug-in miniature relay PRC with power contact, Mounting type: TS 35, 1 Changeover contact, Input voltage: 12 VAC / DC Article number Article name GTIN (EAN) Packaging unit 16256.2 MFR IRCPU 1/24V AC/DC 4044211200381 10 ST Creation date 15.12.2023 17:46:37 Subject to technical changes 10 Data sheet 15502.2 PRC 1/24V DC ##INVERSE##CONTA-ELECTRONICS Multi-function timing relay, Interface-Relay-Compact (IRC) socket base MFR-IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 to 24VAC/DC Article number Article name GTIN (EAN) Packaging unit 16207.2 MFR IRCP 12-24V AC/DC 4044211187446 10 ST Multi-function timing relay, Interface-Relay-Compact (IRC) socket base MFR-FIRCP with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16227.2 MFR FIRCP 12-24V AC/DC 4044211187620 10 ST Creation date 15.12.2023 17:46:37 Subject to technical changes 11
15502.2 价格&库存
很抱歉,暂时无法提供与“15502.2”相匹配的价格&库存,您可以联系我们找货
