15510.2
15510.2
    CONTA-CLIP
    RELAY TERMINAL
15510.2 数据手册
Data sheet 15510.2 PRCU 1/60V AC/DC Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 60 VAC/DC Business data Article number 15510.2 Article name PRCU 1/60V AC/DC GTIN (EAN) 4044211118495 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 35 g Weight per piece (including packaging) 37.67 g Unit of weight G Customs number 85364900 Country of origin QU Product description Relay terminal Creation date 16.12.2023 06:13:28 Subject to technical changes 1 Data sheet 15510.2 PRCU 1/60V AC/DC Technical data Dimensions Length 87.3 mm Width 6.2 mm Height TS 35 / 7.5 with BA 79.9 mm Ratings Rated voltage Un 60 VAC/DC - Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Stripping length 10 mm Torque 0.5 Nm Input data Holding current 0,6 Un AC/DC - Drop-out voltage 0,1 Un AC / 0,05 Un DC Operating range 0,8-1,1 Un AC/DC Power consumption 0,2 W Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 1500 VA Electrical lifespan (AC1) 60x10³ Mechanical lifespan 10x10⁶ Contact load, min. 500 mW Bounce time at close of the NO/NC contact 1/6 ms Materials Contact material AgNi Working temperature, min. -40 °C Working temperature, max. 70 °C Creation date 16.12.2023 06:13:28 Subject to technical changes 2 Data sheet 15510.2 PRCU 1/60V AC/DC Technical data Further technical data Degree of protection IP20 Status display Insulation voltage coil/contact 1 kV Response/release time 5 / 6 ms Insulation voltage contact/contact 6 kV Vibration resistance NO/NC 10/5 g Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 06:13:28 Subject to technical changes 3 Data sheet 15510.2 PRCU 1/60V AC/DC Approvals Standards and regulations CE compliant yes cUL approval CSA-C22.2 No. 14 UL approval UL 508 UL Recognized 1 cUL Recognized 1 Creation date 16.12.2023 06:13:28 Subject to technical changes 4 Data sheet 15510.2 PRCU 1/60V AC/DC Media Creation date 16.12.2023 06:13:28 Subject to technical changes 5 Data sheet 15510.2 PRCU 1/60V AC/DC Accessories Cross-connector External cross-connector insulated for Plug-Relay-Compact (PRC), 20-pole, can be shortened, Voltage: 250 V, Current: 36 A Article number Article name GTIN (EAN) Packaging unit 15545.8 AQI/PRC/20 YE 4044211118440 1 Quick marking Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9107.7 PMC BSTR 6/30 So WH 4044211099749 300 ST Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9106.7 PMC BSTR 6/30 WH 4044211099732 300 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 16.12.2023 06:13:28 Subject to technical changes 6 Data sheet 15510.2 PRCU 1/60V AC/DC Relays Plug-in miniature power relay, With power contact, 1 CO contact, Input voltage: 60 VDC Article number Article name GTIN (EAN) Packaging unit 15503.2 PRC 1/60V DC 4044211118167 10 ST Creation date 16.12.2023 06:13:28 Subject to technical changes 7
15510.2 价格&库存
很抱歉,暂时无法提供与“15510.2”相匹配的价格&库存,您可以联系我们找货
