15559.2
15559.2
    CONTA-CLIP
    SOCKETABLE
    PLUG RELAY
15559.2 数据手册
Data sheet 15559.2 PRC 1/24V DC Au Plug-in miniature power relay, With multi-layer gold contact, 1 CO contact, Input voltage: 24 VDC Business data Article number 15559.2 Article name PRC 1/24V DC Au GTIN (EAN) 4044211118396 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5.2 g Weight per piece (including packaging) 7g Unit of weight G Customs number 85364900 Country of origin CZ Product description Plug-in relay Creation date 16.12.2023 20:28:52 Subject to technical changes 1 Data sheet 15559.2 PRC 1/24V DC Au Technical data Dimensions Length 28 mm Width 5 mm Height 15 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage 16,8-36 VDC - Holding current 0,4 Un - Drop-out voltage 0,05 Un Coil voltage 24 VDC - Power consumption 0,17 W Coil resistance 3390 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 1500 VA Electrical lifespan (AC1) 60x10³ Mechanical lifespan 10x10⁶ Contact load, min. 50 mW Bounce time at close of the NO/NC contact 3/8 ms Materials Contact material AgNi + Au Working temperature, min. -40 °C Working temperature, max. 85 °C Further technical data Degree of protection RTIII (wash-tight) Insulation voltage coil/contact 4 kV Response/release time 12 / 5 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 10/5 g Shock resistance NO/NC 10/5 g Creation date 16.12.2023 20:28:52 Subject to technical changes 2 Data sheet 15559.2 PRC 1/24V DC Au Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 20:28:52 Subject to technical changes 3 Data sheet 15559.2 PRC 1/24V DC Au Approvals Standards and regulations CE compliant Creation date 16.12.2023 20:28:52 yes Subject to technical changes 4 Data sheet 15559.2 PRC 1/24V DC Au Media Creation date 16.12.2023 20:28:52 Subject to technical changes 5 Data sheet 15559.2 PRC 1/24V DC Au Accessories ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16210.2 FIRC 6-12-24V AC/DC 4044211187453 10 ST Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16210.2 FIRC 6-12-24V AC/DC 4044211187453 10 ST Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16213.2 FIRCP 6-12-24V AC/DC 4044211187484 10 ST Interface-Relay-Compact (IRC) socket base FIRC I with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16221.2 FIRCI 6-12-24V AC/DC 4044211187569 10 ST Interface-Relay-Compact (IRC) socket base FIRC O with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16224.2 FIRCO 6-12-24V AC/DC 4044211187590 10 ST Creation date 16.12.2023 20:28:52 Subject to technical changes 6 Data sheet 15559.2 PRC 1/24V DC Au ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with multi-layer gold contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16128.2 PRCU 1/24V DC Au 4044211178635 10 ST Interface-Relay-Compact (IRC) socket base IRCO with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16204.2 IRCO 6-12-24V AC/DC 4044211187415 10 ST Interface-Relay-Compact (IRC) socket base IRCI with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16201.2 IRCI 6-12-24V AC/DC 4044211187385 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VDC Article number Article name GTIN (EAN) Packaging unit 15494.2 ZPRC 6-12-24V DC 4044211118341 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6.12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15488.2 PRC 6-12-24V AC/DC 4044211118228 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VDC Article number Article name GTIN (EAN) Packaging unit 15490.2 PRC 6-12-24V DC 4044211118266 10 ST Creation date 16.12.2023 20:28:52 Subject to technical changes 7 Data sheet 15559.2 PRC 1/24V DC Au ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15492.2 ZPRC 6-12-24V AC/DC 4044211118297 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with multi-layer gold contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16128.2 PRCU 1/24V DC Au 4044211178635 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRC... with multi-layer gold contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16129.2 ZPRCU 1/24V DC Au 4044211178659 10 ST Multi-function timing relay, Interface-Relay-Compact (IRC) socket base MFR-IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 to 24VAC/DC Article number Article name GTIN (EAN) Packaging unit 16207.2 MFR IRCP 12-24V AC/DC 4044211187446 10 ST Multi-function timing relay, Interface-Relay-Compact (IRC) socket base MFR-FIRCP with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 to 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16227.2 MFR FIRCP 12-24V AC/DC 4044211187620 10 ST Creation date 16.12.2023 20:28:52 Subject to technical changes 8
15559.2 价格&库存
很抱歉,暂时无法提供与“15559.2”相匹配的价格&库存,您可以联系我们找货
