15560.2
15560.2
    CONTA-CLIP
    PLUG RELAY
15560.2 数据手册
Data sheet 15560.2 PRC 1/48V DC Au Plug-in miniature power relay, With multi-layer gold contact, 1 CO contact, Input voltage: 48 VDC Business data Article number 15560.2 Article name PRC 1/48V DC Au GTIN (EAN) 4044211118402 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5.2 g Weight per piece (including packaging) 7g Unit of weight G Customs number 85364900 Country of origin ES Product description Plug-in relay Creation date 15.12.2023 04:33:40 Subject to technical changes 1 Data sheet 15560.2 PRC 1/48V DC Au Technical data Dimensions Length 28 mm Width 5 mm Height 15 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage 33,6-72 VDC - Holding current 0,4 Un - Drop-out voltage 0,05 Un Coil voltage 48 VDC - Power consumption 0,217 W Coil resistance 10600 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 1500 VA Electrical lifespan (AC1) 60x10³ Mechanical lifespan 10x10⁶ Contact load, min. 50 mW Bounce time at close of the NO/NC contact 3/8 ms Materials Contact material AgNi + Au Working temperature, min. -40 °C Working temperature, max. 85 °C Further technical data Degree of protection RTIII (wash-tight) Insulation voltage coil/contact 4 kV Response/release time 12 / 5 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 10/5 g Shock resistance NO/NC 10/5 g Creation date 15.12.2023 04:33:40 Subject to technical changes 2 Data sheet 15560.2 PRC 1/48V DC Au Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 04:33:40 Subject to technical changes 3 Data sheet 15560.2 PRC 1/48V DC Au Approvals Standards and regulations CE compliant Creation date 15.12.2023 04:33:40 yes Subject to technical changes 4 Data sheet 15560.2 PRC 1/48V DC Au Media Creation date 15.12.2023 04:33:40 Subject to technical changes 5 Data sheet 15560.2 PRC 1/48V DC Au Accessories ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 48 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15496.2 PRC 48-60V AC/DC 4044211118235 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 648 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15498.2 ZPRC 48-60V AC/DC 4044211118303 10 ST Creation date 15.12.2023 04:33:40 Subject to technical changes 6
15560.2 价格&库存
很抱歉,暂时无法提供与“15560.2”相匹配的价格&库存,您可以联系我们找货
