15568.2
    CONTA-CLIP
    PLUG RELAY
15568.2 数据手册
Data sheet 15568.2 PRC 1/60V DC Au Plug-in miniature power relay, With multi-layer gold contact, 1 CO contact, Input voltage: 60 VDC Business data Article number 15568.2 Article name PRC 1/60V DC Au GTIN (EAN) 4044211118419 Packaging unit 10 Quantity unit PC Weight per piece (not including packaging) 5.2 g Weight per piece (including packaging) 7g Unit of weight G Customs number 85364900 Country of origin CZ Product description Plug-in relay Creation date 16.12.2023 12:08:46 Subject to technical changes 1 Data sheet 15568.2 PRC 1/60V DC Au Technical data Dimensions Length 28 mm Width 5 mm Height 15 mm Ratings Overvoltage category III Contamination degree 3 (250 VAC) / 2 (400 VAC) Input data Working voltage 42-90 VDC - Holding current 0,4 Un - Drop-out voltage 0,05 Un Coil voltage 60 VDC - Power consumption 0,176 W Coil resistance 20500 Ohm Output data Switching voltage / switching voltage max. 250 / 400 VAC Continuous current max. / Inrush current max. 6 / 10 A Contact configuration 1 CO contact Switching capacity, max. 1500 VA Electrical lifespan (AC1) 60x10³ Mechanical lifespan 10x10⁶ Contact load, min. 50 mW Bounce time at close of the NO/NC contact 3/8 ms Materials Contact material AgNi + Au Working temperature, min. -40 °C Working temperature, max. 85 °C Further technical data Degree of protection RTIII (wash-tight) Insulation voltage coil/contact 4 kV Response/release time 12 / 5 ms Insulation voltage contact/contact 1 kV Vibration resistance NO/NC 10/5 g Shock resistance NO/NC 10/5 g Creation date 16.12.2023 12:08:46 Subject to technical changes 2 Data sheet 15568.2 PRC 1/60V DC Au Technical data Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 12:08:46 Subject to technical changes 3 Data sheet 15568.2 PRC 1/60V DC Au Approvals Standards and regulations CE compliant Creation date 16.12.2023 12:08:46 yes Subject to technical changes 4 Data sheet 15568.2 PRC 1/60V DC Au Media Creation date 16.12.2023 12:08:46 Subject to technical changes 5 Data sheet 15568.2 PRC 1/60V DC Au Accessories ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base IRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16191.2 IRC 110...125V AC/DC 4044211187279 10 ST Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16211.2 FIRC 110...125V AC/DC 4044211187460 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 VDC Article number Article name GTIN (EAN) Packaging unit 16218.2 FIRCP 220V DC 4044211187538 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16215.2 FIRCP 110...125V AC/DC 4044211187514 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16216.2 FIRCP 230...240V AC 4044211187507 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VDC Article number Article name GTIN (EAN) Packaging unit 16217.2 FIRCP 110...125V DC 4044211187521 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 6 Data sheet 15568.2 PRC 1/60V DC Au ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base IRCI with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16203.2 IRCI 230...240V AC 4044211187408 10 ST Interface-Relay-Compact (IRC) socket base IRCO with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16205.2 IRCO 110...125V AC/DC 4044211187422 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 VDC Article number Article name GTIN (EAN) Packaging unit 16218.2 FIRCP 220V DC 4044211187538 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16219.2 FIRCP LW 110...125V AC/DC 4044211187545 10 ST Interface-Relay-Compact (IRC) socket base FIRC P with Push-In connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16220.2 FIRCP LW 230...240V AC 4044211187552 10 ST Interface-Relay-Compact (IRC) socket base FIRC I with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16222.2 FIRCI 110...125V AC/DC 4044211187576 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 7 Data sheet 15568.2 PRC 1/60V DC Au ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base FIRC I with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16223.2 FIRCI 230...240V AC 4044211187583 10 ST Interface-Relay-Compact (IRC) socket base FIRC O with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16225.2 FIRCO 110...125V AC/DC 4044211187606 10 ST Interface-Relay-Compact (IRC) socket base IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16194.2 IRCP 60V AC/DC 4044211187309 10 ST Interface-Relay-Compact (IRC) socket base IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16194.2 IRCP 60V AC/DC 4044211187309 10 ST Interface-Relay-Compact (IRC) socket base IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16195.2 IRCP 110...125V AC/DC 4044211187316 10 ST Interface-Relay-Compact (IRC) socket base IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16196.2 IRCP 230...240V AC 4044211187323 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 8 Data sheet 15568.2 PRC 1/60V DC Au ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base IRCI with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16203.2 IRCI 230...240V AC 4044211187408 10 ST Interface-Relay-Compact (IRC) socket base IRCO with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16205.2 IRCO 110...125V AC/DC 4044211187422 10 ST Interface-Relay-Compact (IRC) socket base FIRC with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16212.2 FIRC 230...240V AC 4044211187477 10 ST Interface-Relay-Compact (IRC) socket base FIRC O with Push-In connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16226.2 FIRCO 230...240V AC 4044211187613 10 ST Interface-Relay-Compact (IRC) socket base IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VDC Article number Article name GTIN (EAN) Packaging unit 16197.2 IRCP 110...125V DC 4044211187347 10 ST Interface-Relay-Compact (IRC) socket base IRCP with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 VDC Article number Article name GTIN (EAN) Packaging unit 16198.2 IRCP 220V DC 4044211187354 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 9 Data sheet 15568.2 PRC 1/60V DC Au ##INVERSE##CONTA-ELECTRONICS Interface-Relay-Compact (IRC) socket base IPRC with screw connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16199.2 IRCP LW 110...125V AC/DC 4044211187361 10 ST Interface-Relay-Compact (IRC) socket base IPRC with screw connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 16200.2 IRCP LW 230...240V AC 4044211187378 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15493.2 ZPRC 220...240V AC/DC 4044211118334 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15555.2 PRC LW 110...125V AC/DC 4044211118280 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15556.2 ZPRC LW 110...125V AC/DC 4044211118358 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 10 Data sheet 15568.2 PRC 1/60V DC Au ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC Article number Article name GTIN (EAN) Packaging unit 16145.2 PRC 230...240V AC 4044211189532 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15489.2 PRC 220...240V AC/DC 4044211118259 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC Article number Article name GTIN (EAN) Packaging unit 15491.2 PRC LW 220...240V AC 4044211118273 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC Article number Article name GTIN (EAN) Packaging unit 15495.2 ZPRC LW 220...240V AC 4044211118365 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 48 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15496.2 PRC 48-60V AC/DC 4044211118235 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15497.2 PRC 110...125V AC/DC 4044211118242 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 11 Data sheet 15568.2 PRC 1/60V DC Au ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 648 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15498.2 ZPRC 48-60V AC/DC 4044211118303 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15499.2 ZPRC 110...125V AC/DC 4044211118327 10 ST Creation date 16.12.2023 12:08:46 Subject to technical changes 12
15568.2 价格&库存
很抱歉,暂时无法提供与“15568.2”相匹配的价格&库存,您可以联系我们找货
  • 10+147.7596310+18.48740
