Data sheet
1565.2 RK 16/35 N/PE BKYE
Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16
mm², Width: 12 mm, Colour: Black-yellow
Business data
Article number
1565.2
Article name
RK 16/35 N/PE BKYE
GTIN (EAN)
4044211047368
Packaging unit
50
Quantity unit
PC
Weight per piece (not including packaging)
27 g
Weight per piece (including packaging)
28.44 g
Unit of weight
G
Customs number
85369010
Country of origin
CZ
Product description
Colour
Black-yellow
Creation date 16.12.2023 20:32:34
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
54 mm
Width
12 mm
Height TS 35/7.5
47 mm
Ratings
Rated voltage
800 V
Rated current
76 A
Rated cross-section
16 mm²
Rated impulse voltage
8 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
2.43 W
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
2.5 mm²
Wire cross-section single core (rigid)/stranded, max.
25 mm²
Wire cross-section stranded, min.
2.5 mm²
Wire cross-section stranded, max.
16 mm²
Wire cross-section stranded with wire-end ferrules,
min.
2.5 mm²
max.
16 mm²
Wire cross-section AWG, min.
10
Wire cross-section AWG, max.
6
Stripping length
15 mm
Screw head
Slotted
Screw threading
M5
Tightening torque, min.
2 Nm
Tightening torque, max.
4 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
B7
Number of cross-connection channels
1
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
85 A
CSA wire cross-section AWG, min.
12
CSA wire cross-section AWG, max.
4
CSA stripping length
15 mm
CSA File Number
042110_0_000
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
85 A
CSAus wire cross-section AWG, min.
12
CSAus wire cross-section AWG, max.
4
CSAus stripping length
15 mm
CSAus File Number
042110_0_000
cUL Recognized
cUL approval
C22.2 No 158
cUL Usegroup C: rated voltage
600 V
cUL Usegroup C: rated current
85 A
cUL wire cross-section single-core (rigid) AWG, min.
10
cUL wire cross-section single-core (rigid) AWG, max. 4
cUL wire cross-section stranded AWG, min.
10
cUL wire cross-section stranded AWG, max.
4
cUL torque
20 Nm
cUL wire material
Cu
cUL File Number
E95701
cUL Recognized
1
4
Data sheet
Approvals
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
800 V
KEMA rated current
76 A
KEMA rated impulse voltage
8 kV
KEMA wire cross-section single core (rigid), min.
2.5 mm²
KEMA wire cross-section single-core (rigid), max.
25 mm²
KEMA wire cross-section stranded, min.
2.5 mm²
KEMA wire cross-section stranded, max.
16 mm²
UL Recognized
UL approval
UL 1059
600 V
85 A
10
4
10
4
UL torque
20 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL File Number
E95701
UL Recognized
1
German Lloyd approval
DNV GL Certificate number
TAE000014T
DNV GL Location Classes
Temperature: B, Humidity: B, Vibration: A
DNV GL approval granted
1
DNV GL rated cross-section
16 mm²
DNV GL rated current
76 A
DNV GL rated voltage
800 V
DNV GL test standard
IEC 60947-7-1:2002
5
Data sheet
Media
6
Data sheet
Accessories
Cover
Cover, Length: 26.5 mm, Width: 12 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
2967.0
AD 1/12/N WH
4044211056964
20 ST
Cover, Length: 26.5 mm, Width: 12 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2955.0
AD 1/12/N/B YE
4044211056834
20 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
Cross-connector
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 20.1 mm,
Rated cross-section: 16 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2257.0
Q2
4044211050702
20 ST
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 115.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2266.0
Q 10
4044211050757
10 ST
7
Data sheet
Cross-connector
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 32 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2258.0
Q3
4044211050719
20 ST
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 43.9 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2265.0
Q4
4044211050740
10 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1087.0
SDB 0,8x4,0
4044211014803
1 ST
8
